How Can We Help?
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Hey Benny
Im looking for the electrical connection that attaches to the top of the fuel pump in a 22 Rubicon 392. Also if there is a matching mate to that plug, I’m looking to extend the fuel pump wire harness and not cut the factory wires. Even if I have to buy the plugs and terminals separately, it would be great just to get part numbers. My dealer says they can only get a full harness not individual parts. Appreciate any help.
Hi,
The only side thats available is the harness pigtail which is https://parts.allmoparparts.com/oem-parts/mopar-wiring-68528118aa
If you can find a used pump on ebay you may be able to build something but that connector is part of the top of the module so its not as easy as cutting the connector end off.
Here are the connector details to the pigtail I linked
Jeep Wrangler JL How Can We Help? 1731365381216-1g
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Thank you. Please keep in mind these are parts specifically for the 37" tire ready kit, not the basic 2" lift. I basically need anything but the easy to find parts (easy to find are the wheels, fender flares, CHMSL, Tire Pressure Monitors, etc).
Need PN's for
Shocks, Springs, Steering Damper. control arms., high performance front brake kit...
That is why it would be easier just to get the BOM for the master part.
Got it, OK lets see what Mopar comes back with
- Benny
Atomic-Mouse
Northeast
Hi,
- Benny
Thanks for the help, at least now I know what each wire powers. I was hopeful the plug was used elsewhere on other components, figures it’s a one off. Thanks again for the info. 👍
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
It may be but the way mopar lists them is not helpful in locating it. Take a look at https://connectorrepairkit.mopar.com/ as it may be helpful.
- Benny
mikek1971
mike
columbus ohio
wrangler rubicon, grand cherokee and a cherokee
would these be different since they are part of a 37 inch kit than what came with my 2022 392 xtreme package. i have stock tire carrier and rear bumper. after installing a 37 in tire on rear carrier i now keep getting a message to clean the rear park sensors and rear park switch lights up. it still works just keep getting a message. no weights of tire pressure moniter is on the bottom. valve stem is at 12:00. i was thinking some of these parts may fix my issue. since this kit is made for 37 inch tire
GinaC
Gina
Newport, VT
2026 Willys 2.0T 2DR Hard Top in Mojito built for me!
Yes, I have cloth seats. That's exactly what I need, thank you!
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
No sounds like you have the same parts already but if you send me your VIN I can doublecheck.
- Benny
CurtPopejoy
Curt
Pittsburg, KS
steelerswire.usatoday.com
2021 Jeep Wrangler JL 4DR
SPED Teacher and Digital Editor for USA TODAY
Hi Guys!
We are pleased to have the opportunity to support such a dedicated and enthusiastic forum. As an authorized Mopar Parts and Accessory retailer we are here to help answer any product questions you may have. We also welcome any part inquiries you may have no matter how big or small. I should also note we have some of the best pricing around :rock:
Please feel free to reply here with any inquiries!
Thank you,
Benny
Benny, I just got this Jeep and it was minus two bolts. I attached a pic. Can you help me with what to search for to order replacement ones? Thanks!!!
Jeep Wrangler JL How Can We Help? PXL_20241015_215739106-EDIT (2)
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
ym0bc1
San Francisco Bay Area
JLUR
Hi, I purchased 68609110AA a few months ago, and haven't got chance to install it.
When I open the box (box labeled 68609110AA), but the PCV body has 68210345AC. Do you know if this is expected?
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
Yes. This PCV valve # is a bit of an enigma. It is mentioned on TSB's and differs than the original equipment number but from all experiences we have had it appears to be the same as the OE one. I am not sure if Mopar created an alternate part # so that they can track TSB repairs or what.
- Benny
ym0bc1
JLUR
Hi,
- Benny
Do you know when was 68210345AC started to be equipped (or start selling instead of predecessor)
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Its usage started in 2016 in all 3.6L applications including the Wrangler, Grand Cherokee, Durango etc... Up to 2022 specifically for the Wrangler.
Then in 2023 there was part # 68548886AB which was superseded by 68548886AC
Im curious myslef what this new # is about. I can sell you one at cost if you would like to research and report back.
- Benny
