How Can We Help?
wranglerflx
naples me
2017 4runner 2019 wrangler sport
I am looking for a tailgate harness to replace\match my newly installed
tailgate power latch ref code 68282968AA
see the connector marked '1' with blue marker and going to ... i am not sure maybe the BCM ?
my original harness has two wires (corresponding to tailgate open/close sense wires) and I need one that adds lock/unlock logic
please advise
ref 2019 Sport Wrangler VIN ******551600
Jeep Wrangler JL How Can We Help? swing door bypass
troubledog
Houston
2021 Jeep Wrangler Rubicon diesel
It should be located under the rear cargo floor, I personally do not own a JL but this is what I have read from research.
- Benny
thanks Benny - it isn't there with the other tools... will look again and then call dealer
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
please advise
As per our data the tailgate harness is part of the body harness
Jeep Wrangler JL How Can We Help? 1612387539705
However there is a 3 way jumper harness part # 68351167AA but from here you will need to run your own wiring to the BCM if those circuits are not currently present.
Please let me know if you have any questions.
Thanks,
-Benny
Altitude2020
Canada
2020 Jeep Wrangler JLU Altitude
Mopar Brake Controller
Hi Benny, any update on the Mopar brake controller. I do have the ADH build code on my Jeep. My vin is 1C4HJXEG6LW112656. The dealership here does not have any information on how to fix the issue I have with the lights coming on the dash when I manually press the brake on the controller. The dealership mentioned replacing the unit.
Rubi II
Central Massachusetts
2020 JLUR
Thank you, I will drop the bulletin of at the dealership tomorrow. That was not done. See if it works.
Altitude, I had the same problem and after a long process, the dealership found this TSB (08-019-21) and it worked. No more lights flashing on the dash with and without connection to trailer. Good luck!
Big shout out to OMTBiker for previous TSB that made my dealership investigate further.
Altitude2020
Canada
I have it printed and going tomorrow to drop it off. Hopefully it will work.
DanW
Indiana
Hi Benny, I am wondering if Mopar offers 4.56 gear sets for the JL Rubicons front/rear differentials, and if so, would you be able to give me a quote? Thanks!
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Dan,
None that I can see. The OE ratios are 3:73 and 4:10. Mopar offers a performance ring & pinion kit in 4:88 but if you want 4:56's from mopar you would have to swap to the Dana ultimate axle assemblies https://www.allmoparparts.com/sku/77072529.html
Thanks,
-Benny
40”JLURD
Ross
Southern California
2021 JL Unlimited Rubicon Diesel
Bad Mother Fucker
@AllMoparParts.com
Do you guys offer anything like this for the JL?? Or would this possibly work on a JL?
I sure hope so because I just got Dana Ultimate 60’s and the factory Rubi brake master isn’t enough anymore and I can’t find a viable upgrade!!!
Jeep Wrangler JL How Can We Help? 6107DE66-5C45-4929-9467-8BE2C0F37DAC
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Ross,
I am sorry I do not see an upgraded Master available. In doing some research I can see that the Gladiator uses a different part number master, I am wondering if this is due to the increased weight of the vehicle meaning that it should have increased brake pressure. I will search around to see if this has been retrofitted before.
- Benny
acenines3
NJ
2018 Jeep Wrangler Sport JL
I was wondering if the hardware kit that come with the Mounting bracket lower a pillar #82215427AB Can be bought separately . If so how much.
Thanks for your reply,
Volstock
Bob
Tennessee
2021 Jeep Wrangler Sport Altitude
Info Sec
Hi Benny,
I was looking for a hood lock for the 2021 JLU and noticed that part number 82215137AB does not list 2021 as compatible. Was there a change to the grill or supporting structure that would prevent this from working?
Thanks,
Bob
Gazelle
Eric
Seattle
JLUR 4xe ordered 11/6/20; delivered 5/13/21
Hi Benny,
I'm looking for price and availability for the Mopar suspension lift on a 4xe. Supposedly, the part number is 77072522aa, but I've not seen any supplier able to verify/identify/order this kit yet. It does not show up on a search from your website. Do you have other sources where you could look this up?
Thanks.
