How Can We Help?
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Hi Benny, could you tell me if these come with the inner fender too? Also would my sport lights fit in there or do I need to switch lights too?
Fender Flares - Black - 4-Door - Mopar (82215742AC)
thanks in advance
Hi Joe,
Yes inners are included as they are different and lights are also included so you dont need to swap.
Please let me know if you have any other questions.
Thanks,
-Benny
Jitzy
Orlando, Florida
2020 JLU Willys
Retired Police, Now Certified Custom Club Fitter
Hi Joe,
Thanks,
-Benny
Thank you, these are the textured black ones right and don’t need to be painted? Also are there any codes for these or are they already the lowest price available?
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Correct. I sent you a PM
Thanks,
Benny
cm88_bruins
Ciro
Manchester. NH
2020 Jeep Wrangler JLU Sport S
Hi,
Sure here are links to the parts requested
7" with Sirius XM
https://parts.allmoparparts.com/oem-parts/mopar-radio-68420237ac
8.4" - This is on backorder until June/July
https://parts.allmoparparts.com/oem-parts/mopar-display-system-68429173ab
7" Bezel
https://parts.allmoparparts.com/oem-parts/mopar-radio-bezel-6ab53tx7aa
8.4" Bezel
https://parts.allmoparparts.com/oem-parts/mopar-radio-bezel-6ab55tx7ab
Let me know what your thinking and if you have any other questions.
-Benny
Is the 2020 Wrangler 8.4” 68429173ab for NAV or Non-NAV?
Any idea the difference between that one and 68295725AH?
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Yes from my understanding they are all Nav. The 68295725AH is used in 2018's. The 68429173AB is used in 2019 & 2020
Thanks,
-Benny
4xFUN
Scottsdale AZ
2020 2-door Rubi. 2023 RAM TRX
Hi Tony,
I think I misunderstood your initial request and now understand your looking for the springs from the Mopar lift kit. They are as follows:
https://parts.allmoparparts.com/oem-parts/mopar-spring-front-coil-68414069aa
https://parts.allmoparparts.com/oem-parts/mopar-spring-front-coil-68414071aa
https://parts.allmoparparts.com/oem-parts/mopar-spring-rear-coil-68414070aa
https://parts.allmoparparts.com/oem-parts/mopar-spring-rear-coil-68414072aa
Thanks,
-Benny
Does your parts book also show left & right or do you just go by the Mopar lift kit instructions?
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Mike,
Please clarify which kit and I will see if they breakout the locations.
Thanks,
Benny
4xFUN
Scottsdale AZ
Hi Mike,
Thanks,
Benny
Thanks Benny! The Mopar kit number is 77072396AD, front springs in this kit are: Left 6841 4069AA (69AA is the longer spring-I measured), Right 6841 4071AA (71AA is the shorter spring-I measured)...This is from the Mopar instructions, I checked the springs to verify which was longer. The rear springs included with the kit: Left 6841 4070AA and Right 6841 4072AA, as these are installed and I do not yet have replacements, I cannot tell you which of these are the longer springs.
I thought I could get an idea from cross referencing the OEM spring part numbers with Mopar on-line parts breakdown but that was futile-I found as many listings showing the same part number for 'right front' as I did showing the same part number for 'left front'...
The general consensus seems to be that the taller/longer springs go on the passenger side-which makes sense with the extra weight of the gas tank/skids along with the right rear mounted tire carrier. Unfortunately I did not mark the OEM springs as left and right when I removed them to install the Mopar kit.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
rdrjohn
East Bay, Norcal
2019 Wrangler Unlimited Sport-S
Hi Benny ~ I am looking for the part number for the JL front/rear brake banjo bolt and washer
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Sure, They are the same for front or rear
Bolt 6512427AA
Washer 6502114
Thanks,
-Benny
Cypher
J
AZ
Cybersecurity Leader
Looking for the TPMS part number and price for a 2020 JLUR. I have read that the 2020 wrangler and Gladiator have a new TPMS, but can't find the actual part number or price as most online stores don't show the 2020s.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
It should be the same as the Glad but send me your VIN to validate
Thanks,
Benny
Cypher
J
AZ
Hi,
Thanks,
Benny
I worked with my local dealer to get the part number. It is actually not the same as the Gladiator. I assume maybe since the gladiator supports beep at set tire pressure, but wrangler does not.
anyways, here are the part number I was given in case anyone else needs the TPMS sensor for a 2020 JLUR
68402371AA
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
I see, Thanks!
- Benny
