How Can We Help?
marsh1
Houston
2024 392 Final Edition
I am going to cut down the crush cans on my 392 Final Edition. What are the part numbers for the crush can plastic covers for non winch Wrangler?
Membrain
Dirk
DFW TX
'21 XR392 / '24 XR392
Engineer
My question is on the difference between the Diesel and 392 Wrangler battery boxes where the FUSE boxes are mounted.
I am specifically looking to know/understand why the fuse box of the Diesel Wrangler sits ~2" lower than the fuse box of the 392 Wrangler when everything else looks to be installed/mounted in similar locations on that side of the engine compartment.
The 392 fuse box has ~3" of space below it.
1. Do the battery boxes have the same part number?
1a. If not what are the specific part numbers using the VINs referenced below?
2. Do the fuse boxes have the same part number?
2a. If not what are the specific part numbers using the VINs referenced below?
I offer the following VINs to use for answering my questions:
2021 392 Wrangler: 1C4JJXSJ4MW824344
2021 Diesel Wrangler: 1C4JJXFM4MW526414
I want to see if I can swap out my 392 battery and/or fuse box to have the lower fuse box from the Diesel model.
Thanks!
JJ_WA
JJ
Puget Sound, WA state
2002 Dakota, 2017 Cherokee, 2023 Willys XR
Retired US Army, Higher Education
Hi Benny,
What is the correct name and part number for the 10 bolt faux beadlock rings for the '23 Xtreme Recon models? The wheel is listed as 17–Inch x 8.0–Inch Beadlock–Capable Wheel on my window sticker.
Please include info on the the screws, too.
Thanks!
kablam0r
Bryan
Charleston
2018 Jeep Wrangler JL
Hi Bryan,
I wouldnt say there are specific versions of seals. There is a revised/improved header seal that includes the corner muckets shown in your first pic, This is linked below
https://parts.allmoparparts.com/oem-parts/mopar-windshield-header-weatherstrip-68271695ai
As for the B pillar muckets they are as follows
Left
https://parts.allmoparparts.com/oem-parts/mopar-b-pillar-belt-body-side-seal-left-68271723ae
Right
https://parts.allmoparparts.com/oem-parts/mopar-b-pillar-belt-body-side-seal-right-68271722ae
I will send you a cod you can use but please let me know if you have any other questions or need any other info.
- Benny
Thanks @Benny. Do i need any other parts to swap out that seal?
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Hi,
They are as follows
68295559AA
68295558AA
Please let me know if you have any other questions.
Thank you,
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Thanks!
Hi,
I do not have engineering notes as to why Mopar makes these changes but I provided the parts info that I could lookup below
Tray No data shown for this & mopar could not provide it either. I looked up a 23 392 and found part # 5043120AE to be used.
PDC 68520858AA
Tray 68275852AE
PDC 68481780AB
Thank you,
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Benny,
Thanks!
Hi JJ,
Ring is https://www.allmoparparts.com/sku/68614980aa.html
Bolts are https://www.allmoparparts.com/sku/6511068aa.html
Thank you,
- Benny
JJ_WA
JJ
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
Yes I saw your other posts and agree you may as well perform the diverter TSB so you will also need
Left A-Pillar Diverter - 68544153AA
Right A-Pillar Diverter - 68544152AA
Metal Rivets - 6036678AA (x4)
LF Foam 68443149AA
RF Foam 68443148AA
LF header foam 68400393AD
RF header foam 68400392AD
Optional
LR/RR inner foam 68676500AA (x2) needed
LR outer foam 68443147AA
RR outer foam 68443146AA
Thank you,
- Benny
kablam0r
Bryan
Charleston
@Benny Thanks again. I tried to replace the seal this weekend and found all these additional parts were needed after I pulled the old one off.
Steemax
Los Angeles
2022 Rubicon 4xE, 2025 Outback Wilderness
Hello, i'm looking for the center grille portion for the 2022 Rubicon 4xe as well as the front and rear diff cover bolts. Hopefully you can help me. Thanks!
