How Can We Help?
twa8000
Tom
Wisconsin
2019 JLU, 2009 JKU, 2014 WK2
Benny,
I have a 2019 JLU rubicon with the 8.4. I need a new radio.
68429173AB is for a 19-20
68472587AH is for a 21-22
68472587AI is for a 22
From my understanding?
I would just order the one for the 19 that shows it fits my vin. but the AH one is $100 less and AI is $200 less. Is there really a difference? Or is it just the software? Because I have loaded the AI software on my AB radio in the past. I've been told any JL radio 18-22 should work?
GladiSD
J
San Diego, CA
22' AEV 392 JL370, 08' S2000 CR, 08' S2000, 99' SV
Sure...
Heya Benny, I have ordered some parts from you over on the Gladiator side in the past. Super satisfied. Was just curious about the Mopar Sunrider flip back roof for the hardtop and it's availability? thanks in advance
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Benny,
Hi Tom,
We would need your VIN to check the actual production month and day. From what we know they are not cross-compatible, You need to stick with the same year/prod period.
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi J,
It's readily available but a bit pricey to ship due to its size. You can use code 5off.
https://www.allmoparparts.com/sku/82216370aa.html
Please let me know if you have any questions.
Thanks,
-Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
SilverSurfer
Heinrich
South Africa
2020 JL Rubicon 3.6 8-speed Auto
Hi there, can you confirm what the part number is for the Mopar High Top Fender Flare set, black with LED DRL and turn signal..
Is it 82215743AC or is there a new part number.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
That # is being replaced by 82215743AD around May once they become available again.
Thank you,
- Benny
gato
New England
2021 JLUR
How can I buy a replacement Mopar 2" Lift Kit *** FRONT *** shock for a 4 door?
I can see the rear shocks (68316582AC), but not the front shocks ( 68316572AC).
A previously posted link for 68316572AC to your site is broken. Is there a new supersede part number? This is still listed in all the 4-door lift kits from AC to AF.
Thanks.
Saddle Tramp
Mitch
Hays NC
2021 Rubicon 3.0 Turbo Diesel
Benny - can you confirm that 82215367AB will fit a 2021 Rubicon Diesel
Some sites list it as a fit and some say it will not fit.
Thanks in advance
Mitch
trelle2099
Seattle
‘22 Jeep Wrangler JL Sport S
Hi Benny,
I am looking at 68522502AB Instrument Panel Cluster. I see a couple options but Is this the 7.0 inch color screen cluster? Is the speedometer MPH? This is for a ‘22 Wrangler JL 3.6L 6V. Thanks.
Trini
Cali
2022 Jeep Wrangler Sahara 4xe
HI Benny, does the Mopar all weather mats with the red lettering front mats fit the 2022 4xe? Also can the front mats be purchased separately And if so what is the part number?
SRQgunner
Russ
Sarasota FL
2018 Jeep Wrangler JL Unlimted Sport S
@AllMoparParts.com
Benny.. Just want to tell you, that it is really apparent you are an asset to forum member's here and to your employer. Your attitude is good, you are eager to assist and you have been spot on with your replies in regard to parts, etc.. Anyway, Thank you!
Ditto! I've ordered many parts through Benny including my 8.4, Rubicon Fenders air filters, oil filters, in cabin air filters and other numerous parts.
Benny was a tremendous help in helping to figure out the end caps and wheel well close out panels I needed when I upgrade to Rubicon fenders on my Sport S. It all came together an aligns perfect.
Thanks Benny for all you do for us.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Thanks.
Hi,
If we use the install sheet here https://www.allmoparparts.com/docs/77072397AD.PDF
We can see the original number which has superseded to https://parts.allmoparparts.com/p-front-fox-shock-replacement-4-door-jl-wrangler-lift-kit-68316572ac
And the rears have superseded to https://parts.allmoparparts.com/oem-parts/mopar-shock-absorber-68316582ac
If you show me where the original link was I can fix it.
Thank you,
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Thanks in advance
Mitch
Hi Mitch,
Yes it will fit. I believe the issue is with the taller hoods on the 392 and the JT Mojave's
- Benny
