Hi
Lindi181818
Arlind
Albania
Jeep wrangler sahara 2019
Wheels 22x12-44 tires 35x12.5R22 lift ? Can someone tell me how much lift is needed for this Wheels and tires ?
Deleted User 38384
If you're going off-roading I'd get rid of the 22s. It'll look cool on the street, but it's a bit ridiculous to try and go off-roading with 22s. I mean if you were running 37s or 40s, I guess that would be okay, but 35s on 22s, you're losing 2.5 in of sidewall all around the tire. Not really a good idea there.
Again if you're keeping it on the street though, it'll be donktastic! You'll fit right in in Miami!
Jeep Wrangler JL Hi ZomboMeme 3330
MerPinXEss
Kdale NC
‘24 4xe JLU
To add to tredsert also if u go to -18/-10 you will overcome their extra width inside and would almost clear your Sahara fenders…might only need leveling kit
Lindi181818
Lindi181818
Arlind
Albania
Lindi181818
Lindi181818
Arlind
Albania
I will keep it for asphalt, I don't want it for off-road, its good for asphalt?
Deleted User 38384
I would say so. Though at that point you really don't even need the lift unless you want it for looks. I believe you can run 35s on any stock Wrangler. Maybe only with a little bit of rub at full lock. Yeah if you're not looking for articulation, there's really no point going for a lift.
Lindi181818
Lindi181818
Arlind
Albania
Thank you
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
but only for looks, that is, there is no need for a lift?
As with most things, "it depends".
While 35" tires may "fit" in the wheel well w/o a lift, tires do not actually run true to size (they all vary by exact height, and compress a bit when inflated to different psi and under different loads). You may find with the tire you select that you have some rubbing at full lock/turn.
That said, you could certainly put the tires on without a lift and see how it works. If you decide you need a lift, 1.5" to 2.5" is typically what's needed to "properly" accommodate a 35" tire on a non-Rubicon. There's also a component of look/style here, as some people who have no intent to ever go off road like to lift their jeep to get a better look.
In terms of the wheel diameter, for off road use you typically want the wheel to be about 50% of the tire diameter for proper cushioning (17" wheels). On road, this doesn't matter so much and here is where you will see 20" or 22" wheels.
