Lindi181818
Wheels 22x12-44 tires 35x12.5R22 lift ? Can someone tell me how much lift is needed for this Wheels and tires ?
If you're going off-roading I'd get rid of the 22s. It'll look cool on the street, but it's a bit ridiculous to try and go off-roading with 22s. I mean if you were running 37s or 40s, I guess that would be okay, but 35s on 22s, you're losing 2.5 in of sidewall all around the tire. Not really a good idea there.Wheels 22x12-44 tires 35x12.5R22 lift ? Can someone tell me how much lift is needed for this Wheels and tires ?
Again if you're keeping it on the street though, it'll be donktastic! You'll fit right in in Miami!
I would say so. Though at that point you really don't even need the lift unless you want it for looks. I believe you can run 35s on any stock Wrangler. Maybe only with a little bit of rub at full lock. Yeah if you're not looking for articulation, there's really no point going for a lift.I will keep it for asphalt, I don't want it for off-road, its good for asphalt?
Thank youI would say so. Though at that point you really don't even need the lift unless you want it for looks. I believe you can run 35s on any stock Wrangler. Maybe only with a little bit of rub at full lock. Yeah if you're not looking for articulation, there's really no point going for a lift.
As with most things, "it depends".but only for looks, that is, there is no need for a lift?
Im not goin ofroadWheels 22x12-44 tires 35x12.5R22 lift ? Can someone tell me how much lift is needed for this Wheels and tires ?
