Help with mounting Warn winch
Spastec
Adam
BMW X6M
Hi I have a 4 door Rubicon with factory steel bumpers that I am trying to install a Warn Zeon 10S winch to. I have read the directions multiple times and watched videos and have not been able to figure out how to install the front 2 bolts that hold the winch to the winch plate. I can get the rear 2 bolts in but the bumper is the way of putting in the front 2 bolts. The only solution I see is to drill into the bottom of bumper but I wanted advice before I do anything else. If anyone has done this install and can tell me how they got these bolts in please let me know.
WestKY
Jerry
Benton,KY
F150 4x4, Jl 2Dr Sport Granite Cyrstal Metallic
I don't have the factory steel bumper, try attaching a string to the bolts and fish it up thru the holes. I have used the trick on other bumpers before.
Spastec
Adam
BMW X6M
Thanks for the reply. I have about 1 inch gap between the bumper and the plate to get a 2 inch bolt through the hole. I can get the start of the threads into the hole but the bolt is at too much of an angle to go in and up.
Trav.city
Rich
Michigan
2018 Wrangler Unlimited JL Rubicon
Sales Manager
Watch this. I believe he fits it in.
Good luck.
WestKY
Jerry
Benton,KY
I have the Warn Elite bumper underneath it are holes covered by plugs that give you access to push up on them and tighten with socket,by any chance are there plugs under yours?
WestKY
Jerry
Benton,KY
Just remembered something in the winch mounting instructions if your winch mount is 1/4 " or less thick use the 1 1/2" bolts supplied.
Spastec
Adam
BMW X6M
I will try shorter bolts. I didn't remember any that fit those nuts. It is weird that none of the write-ups talk about this step or any of the videos.
WestKY
Jerry
Benton,KY
They were included with my 10s I put on a few days ago and happen to see in the instruction to check plate thickness
Spastec
Adam
BMW X6M
Thanks I will give it a try. You were able to get them in after the bumper was installed?
WestKY
Jerry
Benton,KY
Yes but again I have a warn bumper, mount plate is built in they made sure bolts are accessable
