Rock Hopper
I purchased a MOPAR winch plate and a Warn EVO 10s (thinking the EVO might be a bit smaller than the Zeon).
Unfortunately it appears that the EVO extends out further on one side. So far everything has gone smoothly until it came time to mount the winch on the winch plate. The drivers side seemed to line right up, but when I went to thread the bolts up through the bottom of the winch plate into the winch it would not line up.... upon further inspection this is being caused by the rear of the MOPAR plate where it flips up (just on the outboard sides-circled in red on the photo below) and also causes another mounting issue. The MOPAR plate has "slots" where the plate mounts to L brackets into the frame so that the plate can be adjusted into place. MOPAR uses Torx bolts with their kit, and with the Warn EVO in place it sits right over one of the Torx bolts making it impossible to hold while tightening the nut below. I do not know if I am explaining this correctly, but if someone has mounted the EVO 10s into a Mopar plate they will know exactly what I am referring to.
I've circled the edges of the mopar plate where it flips up and have drawn an arrow to the slot where the torx head bolt is covered by the 10s motor. It appears I would only have to grind down the flipped up edge on one side of the plate since the EVO only hits it on the longer side which is on the left (passenger) side.
I'm hoping to get some advice on how to proceed.
Right now the only options I can see is grinding away some of the material off of the plate where it curls up in back (this should not affect the strength in anyway) and possibly snugging down the ONE torx bolt and tapping the plate into place, then torqueing down the other three. Another possible option would be to change out the Torx head bolt for a traditional one, however there is a space limitation being as the EVO has ridges that extend outward from the center of the winch that may interfere with a larger head on a bolt.
I am wide open to any suggestions or recommendations-and am curious if anyone has done this install (Mopar plate with EVO 10s). I haven't found a single video or instruction for the Warn EVO 10s/Mopar combination.
Thanks in advance,
David (Rock Hopper)
Thanks in advance,
David (Rock Hopper)
