HELP WHEEL SIZE
jeepcreepjl
nick
new york
2021 jeep wrangler jl
I have a stock 2021 jeep wrangler JLU sport can i run a 17x9 -12 offset on 285/70/17 or 285/75/17 without any issues like rubbing or clearance.Thank you
lalalofsky
Ben
Lawrence, Kansas
2020 JLU Sport
I believe that you will clear them fine, the only issue you may have is that when you do anything that is not on road, you could possibly rub your fender flares. You wont rub your control arms lock to lock.
jeepcreepjl
nick
new york
would it be better to get a +18 wheel
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
Depends on your planned use. Conventional wisdom - if your planning to go off road - is smaller wheel, bigger tire. It gives you more side wall for grip when airing down. 17's are kind of the 'sweet spot' for this, but a good rule of thumb is a wheel diameter no larger than half the tire hight.
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
I’m running 285-70-17 Falken Wildpeak AT3W’s on 17x9 Pro Comp Series 33 wheels. 4.75 backspace / -6 offset. No rub at all lock-to-lock.
jeepcreepjl
nick
new york
it's just for daily driven mostly. So either rim should be ok -12 offset or + 18 with the 285/70/17.Thanks for your guys help to i really appreciate it
lalalofsky
Ben
Lawrence, Kansas
2020 JLU Sport
I think with +18mm that would be like 5.2 backspacing, I believe at least close to that, and that is pretty much the stock wheel. If you want some poke you’ll want to go to atleast 4.75 backspacing.
