Help w/ Exterior Door Hinge Bolts
Rotsam
Jason
Austin, TX
Trying to source bolts for the exterior hinges - the ones that affix the hinge to the door, not the retention nut on the bottom. My wife wants to finish the blackout of the hinge, and the pink bolts just make it look weird to us.
Jeep Wrangler JL Help w/ Exterior Door Hinge Bolts IMG_2747
I tried these from JeepBolts: https://jeepbolts.com/products/jl-jeep-wrangler-door-hinge-16-rust-proof-stainless-steel-bolts-set but as you can see, it’s a much smaller fastener than the OEM:
Jeep Wrangler JL Help w/ Exterior Door Hinge Bolts IMG_2748
Anyone have another place to look? I could just strip the paint off of the existing bolts and paint them black, but would prefer to just get a drop in replacement. Thanks in advance!
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
I’ve been using that style bolt, but 10.9 grade for a couple of years, no issues. I think I got them from the bolt depot or usabolts.com. They can take more torque than the 18-8 from jeep bolts.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Why not just use touch up paint. The torx messes up the OEM paint anyway.
munkeymike
Tx
Black plastidip. Clean, mask, spray. Easily comes off too. You should also change out the door hinge bracket to complete the look.
Rotsam
Rotsam
Jason
Austin, TX
Thanks ya’ll - plastidip and touch-up paint would both work, and I do have the body mounted hinges in black as well, so should look great once I get it together.
Was kinda hoping someone would have a magic link to black replacements of the same size, but sounds like elbow grease is the way.
ScotM
Scot
Southern California
I used a 2k black epoxy paint, made up 2 sets, in case of wear from weather.
Jeep Wrangler JL Help w/ Exterior Door Hinge Bolts IMG_5061
