Help, ESC came on threw codes
NyRey87
Nyles
Reno, NV
2021 JLURD
Hey everyone, driving into work today and me Jeep had a slight wobble to it then it threw a bunch of codes. Thankfully I just got off the freeway.
It went into limp mode then the throttle kept engaging even tho I wasn’t pressing it. Was a little on the scary side.
Codes are :
DTC:
2138
0441
BCM DTC:
B17C1-11
C17BC-11
P1514-87
TCM DTC:
P1DB6-00
P215C-0
ABS DTC:
U0401-00
Any help is appreciated, I’m at work now but having trouble focusing because this is causing me to worry.
I have a20’ JLUS 2.0! Just had new 392 axles installed on Friday and hadn’t had any issues until today. Yesterday was the first time I had ever experienced Deathwobble, and
I did adjust my Steering Stabilizer last night because it was pulling slightly left, it was worse this morning. Tire pressure was pretty even on both sides. I also have a full Clayton 2.5” Overland Lift and fox 2.0 shocks. Thanks
GreenWilly
Tony
22 JLU Willy's, 2024 JLR
Codes are :
DTC:
2138
0441
BCM DTC:
B17C1-11
C17BC-11
P1514-87
TCM DTC:
P1DB6-00
P215C-0
ABS DTC:
U0401-00
Did you ever figure out the issue? I have some of these codes pop up after I changed my gears. I'm guessing it is all related to speed sensors or FAD.
NyRey87
NyRey87
Nyles
Reno, NV
2021 JLURD
I cleared the codes and uninstalled the Pedal Commander and I’ve never seen them again.
