Help adding quick disconnect to rear defrost
Willysteach
Daniel
East TN
2024 Wrangler Willys Xtreme Recon
Hey everyone. This is my first post. I have a 2024 JL with a SOT. I love the convenience of the top, but I don’t like the look with doors off/windows out, and the back glass still in. It looks like a relatively straight forward removal, with 4 bolts, 2 hydraulics, 2 wires, and 1 hose. I’d like to make it as quick and easy to remove as possible, but I have 2 concerns and a few questions.
1-I worry that repeated removal and installation of the washer hose will cause it to be loose. A simple solution would be a quick disconnect, like an efi connector on motorcycles. This leads to my first question. Does anyone know the I.d. of the washer hose?
2-My biggest concern is for the rear defrost wire. I’ve read many posts about the connection failing and I definitely want to avoid removing and installing it. I was thinking about a simple electrical quick disconnect for it. My questions for this are- Is this a single wire beneath the insulation? What is the gauge? AI says 12 gauge. Is this a standard braided copper wire, or something different that might make a connector a less than ideal solution? And is there any issue I am not anticipating that would make this a bad idea? Thanks for you help.
Daniel
SmokyMtnsJeepGirl
Sherry
Home of the Blues, Birthplace of Rock and Roll
2021 Sahara JLU 3.6 e-Torque
I'd love to know the answers to these questions, too. I have a '21 JLU, but I'm hoping to still be able to glean some helpful info.
ag4ever
‘82 CJ-8, ‘82 CJ-8, ‘83 CJ-8, ‘26 Moab 392
I would use deutsch connectors. They make them in several sizes. These would be a nice oem style connector that would also be waterproof. These can also be disconnected and reconnected without damage.
Not sure how to handle the washer hose. Maybe a drip irrigation connection of some type.
Willysteach
Daniel
East TN
Definitely going with a deutsch connector. I’m just not sure if it is a single wire (I think it is) and the gauge (I think it’s 12).
Willysteach
Daniel
East TN
I ordered some parts to give it a go. I’ll let you know how it turns out.
Rubi-Doo1
Saint Louis, MO
2026 Wrangler Rubicon X
I think you are on to something here, can’t wait to hear how it goes. I’ve wanted to remove the rear glass on my SOT since I got it!
PT's19Rubi
Paul
NC - Just across river from Uwharrie trails
2019 Rubicon 2D, 3.6, 8A
Retired Electrical Design Engineer
Correct me if I'm wrong, but I believe the hard top is some form of plastic. If so, the cable to defrost will have to be 2 wires. As to wire size, I've never seen a rear defroster with wires larger than 16 gauge and most likely to be 18. I would be very surprised if 12 gauge used.
SmokyMtnsJeepGirl
Sherry
Me too!!!
Willysteach
Daniel
East TN
You may be correct on both. I haven’t had much time to take a closer look. I hope to know the answer to both very soon.
Willysteach
Daniel
East TN
Making slow progress. I had to order a couple of hose disconnects before I got one that worked. This is what I ended up with:
https://www.amazon.com/dp/B0B1LGDFC9?ref_=ppx_hzod_title_mob_b_fed_asin_title_0_0
I’m still waiting for my electrical connector. It looks to definitely be a single wire. It is one continuous loop, so only one wire on each end. The other end must be in the harness on the other side, which already has a disconnect. Also, it looks to be larger than a 16. I would think it would have too much current for a 16 anyway. I will keep everyone posted. I hope to get everything else I need Thursday.
JT23JL
Virginia
2023 Wrangler
Per the wiring diagram that I saw, the rear defroster wire is 2.5mm. That is between a 12 and 14 gauge wire.
Willysteach
Daniel
East TN
Thanks JT23JL. Then I should be good with the connector I ordered.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
This is very similar to the OEM quick connect hose on the hard top. I would think you could order those but probably sold as a much larger assembly.
Willysteach
Daniel
East TN
I have my connectors. Now I’m waiting on another hole cap to experiment with. In the mean time, I made a couple videos of my idea using a paint lid for a mock-up. Unfortunately, I can’t add them because it says the file is too big, even when I break them into 1 minute chunks.
