HELP! 2021 JLU Wont Start!
jbennett_418
jbennett_418
Jordan
Morgantown, WV
2021 Jeep JLUR 2019 Subaru WRX STI Limited
If you start it with the extra battery and see 14.1 you’ll know it’s not the alternator. I’m putting money on bad cell. Winter months bring out the bad in batteries.
It currently ranges between 13.8-13.9V while at idle.
Jeep Wrangler JL HELP! 2021 JLU Wont Start! EB11542F-8543-4C84-BC80-6336872C0791
rhocking
Rick
IL
2020 Wrangler 2.0T JLU Sport S
I am not sure if this is as good as disconnecting the battery and using a volt meter but if you press the start button twice without pressing the brake and then go to the same menu you are in for battery voltage when car is running I think you get the battery voltage without the alternator.
If anyone knows whether this test is not worth anything and the only way to check battery voltage independently is to use the volt meter let me know.
jbennett_418
jbennett_418
Jordan
Morgantown, WV
That might work under normal circumstances, but since my Jeep was completely dead, there were no dash lights or gauges to look at.
