Half Door Windows
IAJeepguy
Nick
Iowa
2021 JLUR EcoDiesel
ACMX
I’ve got the same issue, my only fix so far is a Bungee cord stretching across from door to door.. ?. I tried to adjust mine, but out of the box they were adjusted to max. If I go the other way then they don’t seal at all. Took it to one of my local dealers, techs answer- wait for it… install full doors for better seal… no shit Sherlock… ??‍♂
Some say they have no issue. I honestly think the biggest problem is the door itself and that channel that the uppers slide into, and the fact that the upper is plastic. Mine has such sharp edges it has shaved some of the plastic leg off from sliding it in and out.
Mine leave about a 1/2” or larger gap above 55 mph. Definitely annoying.
Maverick909
I.E.
www.instagram.com
mastrcruse
DJ
Fort Worth, Texas
JLURD
Can you explain exactly how you did the adjustment? Or do you know of a better YouTube video than what Mopar offered? I was so confused.
There are little set screws per window. There's a manual that comes with them that may be available online. Also, youtube video is out there. Worse case, if you cant find them, I can find mine/scan it and send it your way. In my opinion for $4500 they should have been adjusted for me. Depending on what part of Texas you are in, I'd offer to help if around DFW. Or you can take a look at mine.
LisaLittleAlien
Lisa
2021 Jeep Wrangler Rubicon (Dual Doors!!!)
Maverick909
I.E.
www.instagram.com
