Golden Eagle remake?
golden eagle yes no maybe?
  • Total voters
    58
wanderer
wanderer
Ralph
Carlsbad CA
Engineering Geologist
as I recall, it came with a 304 V8 automatic with quadratac 4 whl dr . there was a little lover down on the housing where the transmission protruding into the cab that was your high low. It was full-time four-wheel-drive. Mine had the Levy seat interior so they were like tan with Levi buttons had to be careful cause those buttons would get hot in the sun. I know it also came in a brown metallic color, which was pretty sweet and black, but that was about it I think
DaltonGang
Doesn't Play Well With Others
Something taken from years back.
Trim package is pretty much a level of color, decals and accessories. Renegade and Laredo were 2 others. They seem to change by year also. Without the original hood bird or striping, a Laredo, Renegade or Golden Eagle all pretty much have the same options, levi's seats, clock, tach. Unfortunately there was never an options code in the VIN. The dead give away for the Golden Eagle was usually the wheels. Here's what is on the 1978 According to the Dealers Brochure."Golden Eagle Package: The CJ Golden Eagle package includes tan Levi’s vinyl front bucket and rear bench seats with color keyed interior; full carpeting in brown; the Décor Group (substitutes black anodized rocker panel for chrome) and Convenience Group; tachometer and rally clock; five 8” spoked steel wheels painted gold with black accent stripes; 9-15 Tracket A-T outlined letter tires; wheellip extensions; roll bar; rear swing away spare tire carrier (CJ-7); fixed back panel and rear spare mounted (CJ-5); spare wheel lock; tan Levi’s soft top; special Golden Eagle hood decal with name lettering in gold and black; and body side, front fender and grille striping."
T
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
It was sold in higher numbers in white, but was also available in
black,
Jeep Wrangler JL Golden Eagle remake? {filename}
7E Oak leaf brown,
Jeep Wrangler JL Golden Eagle remake? E86C-EA70-4BBA-9993-2E8552829B5D__22886.1716685946
6D Sand Tan
Jeep Wrangler JL Golden Eagle remake? P1177646__27523.1640213713
OE Dark Green
Jeep Wrangler JL Golden Eagle remake? _DSC0232__03255.1670015505
1E Copper Brown
Jeep Wrangler JL Golden Eagle remake? P1000758__11419.1604953544
Even 4 of these were built in 7Z Sun orange
Jeep Wrangler JL Golden Eagle remake? 1755103855053-zf
There are others that you come across from time to time, but not sure if any others were official factory colors. I was shocked to learn about the orange and green.
DaltonGang
I'd rock it. Bronze wheels, not sure how to get the bird on with the hood vents.
Cut that portion out, after you take the vents out. Then lay the portion of the graphic over the vent, and with a razor knife, cut out the holes. Reassemble.
Sublime
Tom
Farmington, MN
2021 HellaYella Rubicon
black,
Jeep Wrangler JL Golden Eagle remake? 1755107131931-8x
7E Oak leaf brown,
6D Sand Tan
OE Dark Green
1E Copper Brown
This sure beats the color choices offered on new Jeeps.
yokramer
Snark Incarnate
3 different shades of brown and 2 shades of green, black and white?
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Yeah, the Borg-Warner 1339 Quadratrac. With the "Emergency Drive" vacuum switch in the glove box to lock it into part time. It was a design ahead of its time.
Heimkehr
Pennsylvania
2021 JLU 2.0T
so my first Jeep was a 1977 golden Eagle CJ seven
When I ordered the first year, JL I slapped a big gold eagle on the hood I ran to an overheating issue because of a failed thermostat. Current windshield and I needed a truck so I traded it in.
Now I’m back in a white 24 Rubicon X four-door and I’m considering throwing another eagle back on the hood swapping the wheels to either gold or mat black
do it? don’t?
My personal position on the matter is that I'd claim my Jeep as a legitimate re-creation only if I got all of the details right: the correct size and placement of the correct decal(s), the correct wheel design and color, and everything else that could and should be faithfully carried forward from the original.
In other words, no half-measures. :)
If I just installed a sticker on the hood and called it a day, that's fine, but I also wouldn't represent the vehicle as the clone that it isn't.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
You'd need aftermarket wheels. Those OEM 15" wheels wouldn't fit so well on a JL. But a 17" that has the same design would work in spirit.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Yeah, there'd have to be a modest compromise or two here and there, but done right, the overall aesthetic is attainable.
