I have the same changes however when my engine and lock the Jeep, All the changes will be gone when I start the engine again. Does all those setting stay?My OCD doesn’t like different sized font, so I put compass top center
I just started messing with mine. I didn’t see where I could add the current gear... How do I do this?Left Current MPG
Center Avg MPG
Right Range
Center Speedometor
Added the current gear to the gear display. (GOD I wish my RAM had this)
Compass, time, temp, is all on the radio with the 8.4 so this info made the most sense to me without repetition
I want to say that it's in your uconnect if I remember correctlyI just started messing with mine. I didn’t see where I could add the current gear... How do I do this?
That’s odd. It should not change back to default once changed.I have the same changes however when my engine and lock the Jeep, All the changes will be gone when I start the engine again. Does all those setting stay?
Press the up/down button on the steering wheel until you get to where the screen says "Press Ok to Enter Screen Setup". Press OK.I just started messing with mine. I didn’t see where I could add the current gear... How do I do this?
Thanks for your reply, and that's what I tried many many time. I can make changes but it will lost it all when the engine is off and restart the car after like 15min....Press the up/down button on the steering wheel until you get to where the screen says "Press Ok to Enter Screen Setup". Press OK.
Scroll down to "Current Gear". Press OK.
Select "On". Press OK.
I have the same problem.. I can make changes, then save them, and then after a key off, back on.. they go back to what they were before..Thanks for your reply, and that's what I tried many many time. I can make changes but it will lost it all when the engine is off and restart the car after like 15min....
