Fuse for backup camera
Lp5151
HB
Oregon
2022 Rubicon JL diesel
JL 2021 rubicon: Where is fuse for backup camera?
While replacing spare tire, noticed that wire to backup camera had a worn spot on wire exposing a bare wire. Then checked backup camera, black screen except for backup lines. I assume that when removing and replacing spare tire, may have moved wire enough to short out camera. But, can't find fuse for a backup camera, or even front camera ( front camera works). Is backup camera called something else on the fuse map?
Tethmes
Dylan
Michigan
2022 JLWS, 2023 KLR650
Management
I doubt there's a fuse specifically for the camera. The wire just goes straight from the camera into the back of the head unit.
Lp5151
HB
Oregon
I would think there is a fuse between the camera and battery???
Tethmes
Dylan
Michigan
Management
The camera doesn't go to the battery though, it goes into the head unit. The head unit then goes to a fuse, but if that's working in general it's most likely just a problem with the camera or the camera cable.
Lp5151
HB
Oregon
The cable to the camera has a break in the coating to where the braided cable is exposed....that may be problem?
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
That braided cable is generally there to protect the wiring inside. I would unplug and re plug the camera in to see if it starts working. Like @Tethmes mentioned, there is no specific fuse for the camera itself.
Lp5151
HB
Oregon
I've done that a few times, just ordered a new camera, the new one does not work either. Ordered a new wiring harness to see if that helps.
By chance is there a need to "reset" the UConnect system? As far as I can tell everything else works.
