Fuel filler neck question
rickinAZ
Rick
Phoenix
2026 MOAB 392
So...I'm trying to put an additive into my fuel tank using a plastic long-necked funnel, but there is an internal obstruction as a built-in safeguard. How do I get something, other than a fuel station diesel hose, to access the tank? Obviously the filler hose is designed specifically for the job, but my funnel is not.
Bone-headed question from a first time first diesel owner.
Disregard: I found the adapter near the jack. :)
Search is my friend...search is my friend...search is my friend.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
Here is a pic of the adapter @rickinAZ eventually found. It's easy to overlook. The adapter is usually stashed by the factory in the area where the scissor jack is. The black adapter, will be in a clear plastic baggy.
Jeep Wrangler JL Fuel filler neck question 02
Jeep Wrangler JL Fuel filler neck question 11
FloridaSon
Sport Altitude order 2/4/22 Gupton 3/31 home 4/16.
Good to know. Thanks
JeepVT
VT
2021 JLURD
Unfortunately that fuel adapter is too short really. They should’ve made one longer than angles up
Rhinebeck01
Retired at 55 ..
@JeepVT
There are other aftermarket / different brands of fuel adapters available, that guys have purchased and like better / do the job better..
Some guys have actually changed out the plumbing lets call it on the JL, so they do not need a fuel adapter at all.
JeepVT
VT
2021 JLURD
@JeepVT
I seem what people do to change out the guts of the fuel plumbing but that doesn’t interest me. If you know if a different adapter please post it here. I’ve got to find one for the diesel that works
Rhinebeck01
Retired at 55 ..
@JeepVT
I will let other's here chime in (they will) and tell you what aftermarket fuel adapter they use/ prefer/that they have found works best..
For those that would be interested in reworking the plumbing so to speak, so no funne/adapter is needed, read here: https://www.jlwranglerforums.com/fo...e-filler-neck-for-large-diesel-nozzles.48252/
For those that plan to just use the provided "funnel" you might like to know (in case you want a repleacement or extra on hand) that the fuel funnel is
2020-2022 Jeep Fuel Tank Filler Tube Funnel.... Part# 68246866AA
This funnel retails for about $3.00.
CaptStarboard
Australia
www.brisbanejeepclub.com
2020 Jeep JL Wrangler Rubicon 2.2L TD - "Jacko" Punk'n Orange (Old - 2010 Jeep KK Cherokee)
Too funny. They did NOT include this on my export 2.2L diesel! I found out the hard way on a trail an trying to refill from my 20L Jerry can. The rubber and metal spout would not hit all three prongs at once.... so a long screwdriver and hammer sorted the opening...
I'll have to see if they should have included one with my Rubi when new...
Glad to know there is actually a fix for this.
Cheers,
CaptStarboard
