Front Axle CV Boot Replacement
woffman5
Jacob
San Diego
2021 JLU Sahara 4xE, 2021 JTDR
Well, the inevitable happened this weekend (I think!) and we tore a CV boot on the Sahara 4xe whilst out and about at Big Bear Saturday. I was under the Jeep yesterday after we got home trying to find the source of a clunk in the front end (think it's the ball joints, again) when I noticed the pile of grease on the steering knuckle. Luckily, I caught it before the CV joint ate itself. Looking around, it doesn't look like anyone makes just a replacement boot, the whole axle shaft has to be replaced. I understand the concerns with replacing the boot, and the potential for CV joint damage, just curious if anyone had done a boot replacement and had suggestions for which boot to use.
Thanks,
J.R.
jlrusoin
Sean
Indiana
Jeep JL Rubicon
ItemModel #QtySubtotal
RCV Performance Dana 44 Spherical Sealing Technology CV Boot Jeep Wrangler JL | JT 2018-2021 D11391
  • Like
Reactions: J0E
jlrusoin
Sean
Indiana
Jeep JL Rubicon
Many places sell the replacement boot. I needed it quick and ordered one from Vivid Racing
  • Like
Reactions: J0E
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
He has the stock CVs that come with the FT Tcase.
woffman5
Jacob
San Diego
Correct. It's the wife's DD, and it still has a warranty, so I'm trying not to molest it too much, yet.
New stock replacement is on order. I'm going to swap them and find a boot that can be used. The repaired one will go in as a spare and I'll keep an extra boot or two on hand for when this happens again. I'll post part numbers for the boot I find that works.
SPiNZ
Japan
2020 JLU Rubicon
Did you ever find an aftermarket replacement? If not, do you know the diameter of the small end and large end?
Thanks!
Québec
2021 JLUR
Any news on this? I got a broken boot and would like to just replace the boot...
Québec
2021 JLUR
I did finally replace the boot on my gladiator.
Here is the NAPA boot I bought p/n: UB11 and it fit perfectly . No need for any special tool you slip it over the inner side of the shaft and it goes right in.
GATORB8
CLT NC
Awesome, thanks for sharing.
