Flare Types & Part Numbers
dlong1119
Gainesville, FL
21 Sahara 4xe (StingGray)
Correct, and I mentioned that in my post regarding "high flare" models, ie Rubicon and maybe some of the Willys? All good though and thanks for noting it, hopefully it'll help someone else! To be clear, the flare extensions I was trying to fit were the Amazon copies that are made to the fit the Saharas and low-fender models, so they seemed as if they should have worked. They also incorrectly listed them as fitting 4xe models. After seeing the different in my 4xe flares, I tried them out on a non-4xe at the dealership and they fit perfectly.
Enrico Pallazzo
2022 Wrangler Unlimited Sahara Altitude
Hi,
The Mopar accessory kits like this and others do include Lamps
https://www.allmoparparts.com/sku/82215741ac-fs.html
Please PM me your conversation as I would like to research why you were told otherwise.
Thank you,
- Benny
Hi Benny,
This thread is very helpful, but I want to make sure that I am ordering everything that I need and all of the correct parts for a damaged right(passenger side) 2022 Wrangler Unlimited Sahara Altitude low fender flare with LED lights. I need a paintable fender flare, the plastic piece on the front of the flare below the lights, both side marker and turn/drl lights, as well as replacement mounting hardware. See pic. THANKS in advance!
Jeep Wrangler JL Flare Types & Part Numbers Screenshot 2024-05-21 at 1.50.50 PM
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Hi Benny,
Hi,
Here is a link to the correct part
https://parts.allmoparparts.com/oem-parts/mopar-wheel-flare-molding-right-6ce66tzzah
Youll need to provide Paint and a few new plastic rivets, I can help with those as well if your self installing it. Please note this does show to be on backorder but we may be able to source it from a sister store. I can research this option further if you are interested in purchasing it.
- Benny
Enrico Pallazzo
Hi,
- Benny
Thanks! I appreciate the reply. I’m ready to purchase and want to make sure that I have everything needed to install it myself after paint is done locally (unless you can paint it granite crystal metallic too). I assume that I’ll need the plastic rivets and the “white” clips too.
To verify, it’s a “low” fender that can be painted and includes both LEDs and the front black trim all in that one part number?
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
White clips are included, Rivets/Clips would be
x4 https://parts.allmoparparts.com/oem-parts/mopar-mopar-plastic-rivet-sold-individually-6506007aa
Clips
x7 https://parts.allmoparparts.com/oem-parts/mopar-push-pin-6505411aa
Correct. I will send you a code you can use,
- Benny
JeepRoofer
Cody
Round Rock, TX
2019 JLUR Sport S
Hi,
Clips
- Benny
Hey Benny,
Can you help me out with part numbers for a '23 Jeep JL Rubicon? I only need the front driver side fender flare molding, I have all the guts from a damaged fender flare molding. I just need the paintable version. Thanks for the help.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hey Benny,
Sure Cody,
With Halogen, LED or whatever is cheapest?
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Whatever is cheapest.
There very similar, May be worth getting LED and selling the lamp off
Halogen
https://parts.allmoparparts.com/oem...ng-left-68585461aa?c=az0xJnE9NkNFODFUWlpBSA==
LED
https://parts.allmoparparts.com/oem...ng-left-68585463aa?c=az0xJnE9NkNFODNUWlpBSA==
I noticed the image shows no lamp however these flares always did in the past. I am trying to physically verify this just in the case that mopar made a change. In the meantime I will send you code you can use.
- Benny
JeepRoofer
Cody
Round Rock, TX
2019 JLUR Sport S
Halogen
https://parts.allmoparparts.com/oem-parts/mopar-wheel-flare-molding-left-68585461aa?c=az0xJnE9NkNFODFUWlpBSA==
LED
https://parts.allmoparparts.com/oem-parts/mopar-wheel-flare-molding-left-68585463aa?c=az0xJnE9NkNFODNUWlpBSA==
- Benny
Thank you
Eyeball
1997 TJ & 2023 JLUR
@AllMoparParts.com
Hello Benny, can you direct me to the paintable driver rear fender flare necessary for my 2023 JLUR XR? Also, do I need to order the additional 1” extension separately?
Edit: I am asking for assistance beyond the list in post #1 because I am unsure if the Rubicon XR flare differs from the standard Rubicon painted flare.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
@AllMoparParts.com
Sure here are links to both
https://parts.allmoparparts.com/oem-parts/mopar-wheel-opening-flare-molding-6ce87tzzaf
https://parts.allmoparparts.com/oem-parts/mopar-rear-wheel-opening-spat-left-68536655aa
The flare requires painting and yes the extension is a separate part. I will send you a code you can use.
- Benny
JJ_WA
JJ
Puget Sound, WA state
2002 Dakota, 2017 Cherokee, 2023 Willys XR
Retired US Army, Higher Education
Hi Benny,
I need a full replacement of my left front fender for '23 Willys Xtreme Recon. Fender flare, liner, lights, etc. Do you have it as a complete unit? What is the availability? I'm hoping to have it repaired to go wheeling again in mid-July.
I've DM'd my VIN and other information.
Thanks!
--jj--
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi JJ,
DM replied to
Thanks!
- Benny
