FL Tazer Mini help
fireman9027
Ormond By The Sea FL
JL Rubi 2 Door
Retired Fireman
I got my Jeep back from the shop, and they used the Tazer Mini to set tire size and new gear ratio.
I'm hoping someone in FL somewhere near the Daytona Beach area might be able to show me out to make some other changes.
I'm not good electronically and would really appreciate someone helping me learn how to actually use the Tazer...
Chris D
Phoenix, Arizona
2015 JKURHR Hydro Blue, 2019 JLUR Ocean Blue, 2025 JLURX in Mojito.
The Tazer is a pretty awesome tool, the instructions - wellllll, they could use some improvement. Key things to know up front, how to get into the settings and then how to save after any adjustments. From there, settings are broken into 3 categories, determined by if vehicle is 'on' or 'running' and 'hidden'. Start with the adjustments for when the vehicle is just 'on' make some changes, reboot/2 sleep cycles, and you will have climbed the steepest part of the learning curve. I can this, on the 25 JLUR, the SGW moved from the instructions, took a while to find where someone did actually locate and post the location of the plugs. Didn't lose too much blood getting installed without having to dissemble the dash.
Print the manual, read it, read it again, then go forth and wander.
