Falcon 3.3 Revalve
cmb396
Chad
WV
2018 Crystal Granite JLUR
Just got off the phone with TF in regards to having my 3.3's re-valved, and they told me they have NEVER re-valved a set of shocks, and that anyone on any forum that has said they have are fos!! Then said they came out with the SP2 to address this stiffness issues of the 3.3.
I'd ditch them, but already have front and rear inner fenders specifically cut for the 3.3's. What a crock of shit!
gsxr310
CA
Ditch those along w/ the fenders too??
cmb396
cmb396
Chad
WV
Send me a seed off that money tree in your back yard and I’ll do it! Lol
Have around 2k in that set up
gsxr310
CA
I was seriously considering those shocks for my JT. But I’ve been hearing they are on the stiff side.
Glamisfan
SoCal, 30 minutes from Glamis
2020 Sting-Gray JLUR
If they can be taken apart like any high-end off-road shock then anybody that does shock revalving can take care of them for you. Should cost between $75-$100 per shock.
cmb396
cmb396
Chad
WV
cmb396
cmb396
Chad
WV
What springs are you replacing?
Just stock with RC spacers. Ran this combo to keep close to factory ride, and see if 2.5" was high enough.
quietpeen
Chambersburg, PA
2019 JLUR
The synergy springs are the closest to stock but they are stiffer so I don’t know if you are going to have a positive outcome. I could be and hope I am wrong.
quietpeen
Chambersburg, PA
2019 JLUR
On a side note I am also running a RC 2.5”‘spacer lift for now to see if it is enough lift. I have the RC N3 shocks though
cmb396
cmb396
Chad
WV
I started with just the RC and shock ext and thought the ride was not bad. Went to the 3.3's and it stiffened up some. IDK what the actual spring rate would be on stock springs with the spacer? I would think the compression would stiffen them somewhat? Maybe not, never seen any info on it?
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
According to sources here(https://www.jlwranglerforums.com/forum/threads/spring-rates.16491/), JLU Rubicon Springs - 123/128 Front 172/176 Rear
Synergy -20 series springs are (initial/ride rate) 110/120 front and 140/175 rear for the 4-door 2" springs
I went with the -10 series springs which are even softer at 95/120 front and 115/150 rear
https://www.synergymfg.com/synergy-jeep-jl-jlu-front-lift-coil-springs.html?category_id=4980
https://www.synergymfg.com/synergy-jeep-jl-jlu-rear-lift-coil-springs.html?category_id=4980
quietpeen
Chambersburg, PA
2019 JLUR
good info, I could have sworn I saw someone from Synergy post that their springs were stiffer than oem rubicon ssprings but by less than 10% stiffer. I'm happy to be wrong and hope the o.p. is happy with the new setup
