Factory Tow/Trailer Wiring Issue
TopWright
Richard
Western NC
2019 Rubicon JLU Granite Crystal Metallic
USMC (Ret); IT Specialist K-5 Public School
I have a 2019 JLUR with factory tow package and te 4/7 wire connections. Trailer lights do not work when connected. Fuses checked good. Checked with trouble light and no joy there either. Ideas for the areas to check? I did read that the connection seems to connect behind the passenger tail light and will check there this evening. Any other advice is greatly appreciated.
TrailScooter
'20 Jeep JTR, 91 F1504x4 and so on...
If you've done a lot of wheeling. Check the connector on the back of the plug at the bumper.
Other than that, do you have rats?
TopWright
TopWright
Richard
Western NC
I did unplug connector from the back of the 4/7 pin wiring and all looks good. Plugged back in. No joy. No..no rats. Have a stray cat that lives in my garage going on 8 years now. She earns her keep by leaving me mouse parts and mole parts on the doorstep from time to time. 🙂
TrailScooter
Ah, time to use the multitool, then.
Jeep Wrangler JL Factory Tow/Trailer Wiring Issue Hammer-Bash-696x497
morph860
NSB, FL
'24 JLURX 4xe, '24 GC 4xe
TopWright
TopWright
Richard
Western NC
When you say that you "checked with trouble light", are you referring to something like this?
https://a.co/d/cxdEJoY
Has it worked for you in the past or is this the first time using it? Did you buy the vehicle new?
Here's a link to how the OEM harness gets installed: https://www.quadratec.com/sites/default/files/installation_instructions/K6864082AA.pdf
That might help you locate the wiring.
I checked it with a 4 wire plug like above but wo the 7 pin. I think I will order the one you linked and have it for future. First time using and, no, purchased it used. Thanx for the links.
morph860
NSB, FL
Look up your original build sheet to see if the tow package was really a factory option or if it was added by someone afterwards. The hitch itself is very easy to add but the wiring can be more complicated. Especially if they tried to use the Mopar harness. Some people report needing to have it "activated" by the dealer. Maybe someone added it and never had it activated? Or it didn't get installed correctly. Not needed it you only use it to tow something like a bike rack or cargo rack.
Build Sheet: https://fcagroup.my.site.com/RAM/s/equipment-listing
You'll be looking for "Class II Receiver Hitch" and "7 and 4 Pin Wiring Harness" on the build sheet.
Aturking
Andrew
Avon,OH
2023 Wrangler Unlimited Willys
If all the fuses check out then check the ground on the trailer. Also, I have found it is easy to blow fuses, especially on the 7 pin plug. Always connect with the lights off
gsbrockman
Greg
Sand Gap, KY
2023 Dodge Challenger Scat Pack Plus A8 & F8 Green
Owner / Operator Brockman Hauling, LLC
Those little bastards (and mice, ground squirrels, etc.) can wreak havoc on wiring.
I recently went through this with one of the two 7-way plugs on my CM truck bed on my 2022 RAM 5500 Cab & Chassis.
Jeep Wrangler JL Factory Tow/Trailer Wiring Issue IMG_1725
Jeep Wrangler JL Factory Tow/Trailer Wiring Issue IMG_1720
Jeep Wrangler JL Factory Tow/Trailer Wiring Issue IMG_1726
TopWrightUSMC
Richard
Western NC
2019 JLU Rubicon
Found This:
Jeep Wrangler JL Factory Tow/Trailer Wiring Issue 1722183641043-i5
TopWright
TopWright
Richard
Western NC
That trailer harness is for the Mopar harness install if not from factory right? I see the contol box by the passenger tail light assy. Mine goes thru the fuse box. How or where is my wiring terminated..under dash? Same route as Mopar add on? TIA
TopWrightUSMC
Richard
Western NC
2019 JLU Rubicon
Anyone know the path of the wiring for the 4pin/7pin factory installed tow package? I have the 12v present on the 7pin but no lights (stop or turn) when testing using the 7pin plug in tester.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Brake controller wiring should terminate under the dash. I don't know about the factory, but my Mopar harness (add on) has it's own fuse. Follow the grounds under the hood on passenger side you might find one. Aside from that, it could be the module near the taillight has gone bad.
