etorque start-stop not working after removing engine battery
813 Fabrication & Design
Rock Sponsor (Level 1)
Jeremy
Louisville, KY
2020 Jeep Gladiator / 2022 JLUXR
Does anyone know if there is a reset for the start stop system? I have removed the engine battery a few times while working on some items. The first time the start stop starting working again after driving some but now after taking the battery out again it isn't working after driving for a few days. I don't have any dash lights or warnings showing. Any thoughts?
Jeremy
Louisville, KY
Did you plug the IBS back in?
What does the ESS page on the instrument cluster say?
I will flip through the screens and see what it might say. I don't see any warning lights or error messages. Not sure what the IBS is. I removed +/- terminals from the battery and removed the battery. I did not unplug anything else. I needed access to the battery tray so I needed to pull the battery out.
BrierPatch
West Central Indiana
21 JLU80, 15 WK2, 13 Silverado 1500. Had: 02 TJ
It could be something as simple as the HVAC settings. The instrument cluster should say this if it is the reason, but will only show if you are on the Start/Stop page.
limeade
Guy
Reno, NV
I might be wrong, but I don't think eTorque equipped engines use IBS. IBS is for those non-eTorque versions which use the auxiliary battery. ESS is controlled through other means with the 48V battery.
