Engineering Screen
Danimalnutz
Romansville
2018 JL Mojito Rubicon 4dr Soft Top
Jeep Wrangler JL Engineering Screen untitled
Anybody have any idea what the Cabin eq is? Does it have any relation to the amount of amplified equalizer they pump up stock systems to make them sound better at lower levels?
Danimalnutz
Danimalnutz
Romansville
If you have the 8.4" Uconnect or if you have the active-noise cancelling feature, this may have something to do with that...
I ordered both I can play around with it when I get it. That would make more sense then the eq curve.
doubletap
2014 JKUR
Nobody has active noise-cancelling on their JL. It is an option that will be found on the diesel.
Danimalnutz
Danimalnutz
Romansville
I thought that was part of the infotainment package. Did they scrap it?
TravisRogers
Travis
Annapolis, MD
2018 Jeep Wrangler JL Sahara
Cabin EQ is usually a setting that matches the head unit to the type of speakers/sub/amp you have.
Danimalnutz
Danimalnutz
Romansville
Does it have any effect on the eq curve or adjustable. Like could you do that instead of jl fix or something to get a clean signal?
TravisRogers
Travis
Annapolis, MD
It’s probably going to be more of a high pass/low pass routing filter setting based on the signal the sub amp needs. For example making sure only bass goes to the sub amp. Some models (like the Grand Cherokee) may also have divided speakers throughout the cabin (tweeters up high and mids in the doors), so the head unit acts as a cross over—or a filter that sends the highs to the tweeters (high pass) and mids/bass to the mids (low pass).
Danimalnutz
Danimalnutz
Romansville
That would be great if it that was built in. Does anybody know how to fix the signal in the radio to get true output not the stock weird curve without using a dsp?
Danimalnutz
Danimalnutz
Romansville
Hold down the hot and cold arrows on the drivers side temp control for I think 5-10 seconds
Danimalnutz
Danimalnutz
Romansville
Sierra Nevada
usa
Red Rubi JL Unlimited
If true, then the units would be Hertz. This setting may help the lower mid-range by boosting that number to 120Hz to 320Hz or so. Right now the speaker system sounds too brassy with USB sourced music.
