Engine compartment access point
CanAmMick
Mick
Wyoming
2018 Jeep Wrangler Sahara JL, 2017 Honda Pilot Touring
USAF Retired Helicopter mechanic
I need to run some wire from the AMP Research controller in the engine compartment to the AMP override switch on the drivers side of the Jeep. Where is the easiest place to bring wires through without taking a lot of things apart? Total of three wires with shielding that are about 3/8 of an inch in diameter.
Jeep Wrangler JL Engine compartment access point BD240EBA-362F-4F08-8883-0EB8077B4650
CanAmMick
CanAmMick
Mick
Wyoming
Ormond Beach, Florida
Retired at 55 ..
@CanAmMick
For you with an automatic, the best place for you to go through, would be on the driver's side fire wall.
Look right where the clutch pedal would have come through the firewall, if your JL was a manual.
You will find a plastic covering over that hole and it is easy removed per forum member reports. Watch when you pop the cover out, as you can lose track of that plastic cover.
CanAmMick
CanAmMick
Mick
Wyoming
@CanAmMick
As always, thank you so much! As soon as it warms up a little I’ll get it done.
