DRL Question
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
I did not clear the codes after doing the setting change, maybe that is the culprit. Will give that a try tomorrow and report back.
@jaysmooth24
I have read 3 other posts/past posts where guys had ongoing issues as you and then cleared the codes and all was well after that.. Good chance that will do the deed for your JL, too.
Hey... did you know that Threedom has replacement panels for the Oracle lush tail light offering. You can get rid of the fugly Oracle logo on them. https://www.jlwranglerforums.com/forum/threads/?-order-now-threedom-designer-replacement-panels-for-oracle-flush-mount-tail-lights.89520/#post-1867922
I am a tester of Threedom offerings and just installed the replacement panels. Color match and fit is spot on...
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Well, if you want your JL to not look like all the other JL's you may want to keep it as is... Your JL will be unique.
I get lots of comments regarding my JL having yellow versus white..
With JSCAN you change to yellow for DRL's by doing this:
Turn Signals for DRL's
Maybe need:
ADAPTATION ---> DRL--> Day time running lights Configuration- Canada DRL
ADAPTATION
---> DRL - Day time running lights - settings --> DRL Lamp Location --> Turn Signal DRL
Hadn't seen this one. Just went and swapped it over.
Rhinebeck01
Retired at 55 ..
@Dyolfknip74
It's a cool adaptation that will set your JL apart from all the other's on the road locally.
Somebody should start a tread where forum, JSCAN user's can post, just the JSCAN adaptations they know/use.
If I were to start that thread/post such, some know nothing asshat would post that I am getting a kickback from JSCAN. :facepalm:
Dyolfknip74
2021 JLU Rubicon
@Dyolfknip74
Well, obviously you are :)
Ya, I've already done it. I love the look as well and to be honest, here in Canada where DRLs are on every car by law, it allows the JL to be seen better.
Trk3263
T2
Upstate SC
Jeep Wrangler JLUR
Halogen yellow DRL pic below. Any thoughts on turning down the power on the yellow DRL? Is that an option? Just did the switch and will run the a few day to see how I like them. My old Toyotas had yellow and I always felt they stand out better in bad weather.
Jeep Wrangler JL DRL Question 9A913556-F203-4A2C-A209-AA4160C02336
Rhinebeck01
Retired at 55 ..
@Trk3263
Huh.... my JL and the guy's JL's that posted in this thread are not lighting as your JL. Something looks different/ not good in regard to your JL. (Unless it is a picture angle thing)
Did you use the exact same JSCAN settings as I mentioned early on in this thread.
This is not my JL but my JL lights look like this:
Jeep Wrangler JL DRL Question 893FED4B-197A-4199-AC09-E06A8BD10103
Trk3263
T2
Upstate SC
Jeep Wrangler JLUR
Mine is a 21 JLUR with halogen lights and my turn signals and white DRL are side by side instead of two horizontals like the first pictured jeep. I am thinking the first jeep has LED lights?
Rhinebeck01
Retired at 55 ..
My Keep is a 21 JLUR with halogen lights and my turn signals and white DRL are side by side instead of two horizontals like the first pictured jeep. I am thinking the first jeep has LED lights?
@Trk3263
Yup, that is why there is a difference in appearance then. The other's in the pics in this thread have an LED optioned JL.
