Door open warning
Jeevanjit1110
Jeevanjit Singh
Yellowknife, NT
Rubicon X 2024
Its my 2024 wrangler rubicon X
Video attached
As i sit and close my doors
The dome light go off But when jeep reaches 25km/h It automatically tries to lock doors Then it beeps 2-5 times and say door open
And whenever speed reduces from 25 and again go up to 25 like a turn or something It again beeps and show door open please suggest if you can
also sometimes it does not remote start
Pl
Please suggest if you can
Pape
Quebec
JLU Sahara
This is standard feature to lock the door, can be disabled in the infotainment system.
In regard to the warning, curious can you lock all the door from the lock button and manually ?
I have a feeling one of your lock is not working properly.
Badunit
VA
1997 TJ, 2023 JT
Just a thought:
Looking at the wiring diagram for a '23 Gladiator, which is likely to be similar to your '24 Wrangler, the driver's door has two door ajar sensors (apparently part of the latch). The other doors only have one. It is possible that some of the code uses the one sensor and some uses the other (or both). It might be a bad sensor or a bent pin on a connector or a broken wire. Hopefully a diagnostic tool is capable of showing both sensor inputs to verify they are both working properly. And you can use it to check out the other doors as well.
The blue at the top of the diagram is the body control module.
Jeep Wrangler JL Door open warning Screenshot 2025-11-03 at 8.34.19 AM
