Door check popped inside door
Shooting or Jeeping
2020 JLUR, 2019 RAV4
Well, what he stated, in regards to how to handle, could not have been any clearer.. he stated..
"What you can do (one of a few ways) is take the a much longer bolt and use it in place of your short check strap bolt. The longer bolt will allow you to reach to...to fasten up to the check strap and pull it out of the cavity further. After it is out, remove your long bolt and then use the short bolt to secure the check strap properly. So, guess you will be going to the hardware store. You will be careful next time not to let the check strap go into the cavity."
Yes. This. x100
doubletap
2014 JKUR
This ^^^^^
doubletap
2014 JKUR
This ^^^^^
Waiting
Keith
Baltimore
2018 2-Door Rubicon, 3.6L, 8-spd auto
I deliberately popped my door check strap inside the door to be able to easily take the doors off during summer. To get the door check straps back out, I did the following by taking a shoe lace wrapped through the door check strap bolt hole, around the metal hook for the wiring harness check strap, and over a wrench handle. Hold the shoe lace tight and stationary with the wrench handle. Then, push the door open to the first detent. (I used my foot). At the first detent, there is enough room to get the stock door check strap bolt into the hole in the door jam.
Jeep Wrangler JL Door check popped inside door IMG_0256
Bubba33
Saint Louis, MO
18 jeep wrangler Sahara JL
I just pull it straight out with Vice grips. Put a rag on tighten it up.and pull it right out.
TXHusker
2020 Jeep
Vice grips didn't work for me....but a long (12'') straight slotted screwdriver (inserted through the door check bolt hole and in to the bolt hole on the body of the jeep.....the leverage of the screwdriver and closing the door popped the door check right out).
hoss75
Adam
Warminster PA
2018 Unlimited Sport
I assume you meant "and opening the door popped the door check... ". Otherwise I'm confused. Their needs to be a tool to pull this sucker back out!
TXHusker
2020 Jeep
My bad, yes opening the door.
entropy
Foothills of the San Gabriels
OF top 1% content creator
Thanks you saved my day. I used a coord, tied a nut on the door check hole and wrapped the other end of the coord around my arm and pulled hard at the same time I pushed with my foot. popped right out.
