Disconnect the aux battery problems
mrschwarz
Michael
Arizona
2021 JL Rubicon Unlimited
I have a 21 JLU Rubicon. The ESS light came on a year ago, but I ignored it because everything else was working and I assumed it was the aux battery and ESS wasn't important enough to get it fixed. I had replaced the main battery about the same time, before I even knew about the second one.
I also flat tow the jeep so I pulled one of the LED sense wires out of each tail light so the lights from the tow vehicle wouldn't trigger the BCU to turn on. It resulted in the inside turn signal arrows blinking twice as fast and a message on the dash that the tail lights were out (they weren't) whenever I started the car.
I am getting ready to trade the Jeep in so I thought I would do the aux battery bypass and reconnect the LED sensors in the tail light. This morning, I opened the hood, pulled the F42 fuse and disconnected, what I thought was the aux battery negative. I turned out I disconnected the wrong negative wire. The car would start and the dashboard was dead. I reconnected the negative wire and disconnected the other one. The courtesy lights then came on and the dashboard woke up when I opened the drivers door.
The engine started, the ESS light didn't turn on and the turn signals started blinking at their regular speed again. I put the car in reverse and got a message on the screen that the camera system was not available. Also, the seat heaters and steering wheel heater came on. The AC was set to 'LO' instead of whatever temperature it had been set to.
I shut it off and reconnected the second negative cable, which I assume is the negative to the aux battery and restarted the car. The rear camera started working, but the turn signals still didn't indicate they were out and and the AC was still stuck on 'LO' instead of letting me set the temp. I shut it off and reinserted the F42 fuse. The result was the same.
I don't know if it matters, but the hood was open the whole time.
Any ideas what's going on? How do I recover?
MOOG5050
Ny
Rubicon XR
I would connect everything as previously and replace the fuse. Then disconnect the negative on the main battery for 20min to reset it. Hopefully when you reconnect, all is good.
mrschwarz
Michael
Arizona
I'll try that next. I read in some other threads that it takes time for all the computers to talk to each other before things settle down after reconnecting the battery. I disconnected the aux battery and reset the tail lights. I'll check it again in a couple of hours or so.
Thanks for the response.
bmpcamry09
New Athens, IL
2025 JLU Sport S 3.6 8AT
This is normal on these. If everything is back to stock Just leave everything alone and let the vehicle sit overnight or longer if possible to let all the modules go to sleep. Once they power back up and resume everything will return back to normal.
mrschwarz
Michael
Arizona
If I drive the car in the meantime, does the clock start all over again?
bmpcamry09
New Athens, IL
I believe so. Everything needs time to power down. Don’t even let your key fob get close to it during that wait period
mrschwarz
Michael
Arizona
Thanks. I'll see what it looks like in the morning. I don't think we're going anywhere today.
