Mad Hatter
CarbonSteel, how did you measure that your diff oil(s) ran cooler? Thanks!
Temperature gauges (front and rear). I ran an experiment by tapping a set of OEM covers and towing from Houston to northern Wyoming and repeated the trip a few weeks later with the Mag-Hytecs. I saw 10-15 degrees difference in oil temperatures with (to the extent possible) everything else remaining the same.CarbonSteel, how did you measure that your diff oil(s) ran cooler? Thanks!
I have a friend who TIG welds and so it was not that bad. I was going to change the oil anyway and so I did and then when I switched to the Mag-Hytec, I kept the oil that only a few weeks old and reinstalled it plus the difference to fill it to the full line since the Mag-Hytec held considerably more oil than the OEM cover.Thanks for the explanation. Wow! That's a lot of trouble, but you came up with usable results and conclusions!
