Diesel Oil Filter
Paulguy100
Wisconsin
2021 JLU Rubicon
Is everyone using the Mopar brand or what other?? 48 bucks, wow.
gerlbaum
Greg
Arizona
2021 Wrangle Sport Diesel
Amazon has $18 ones. They’re all the same made in China crap and have the same micron rating. Mind as well get the cheapest. Probably all made on the same assembly line they just aren’t paying the mopar name brand royalty.
rickinAZ
Phoenix
2026 MOAB 392
Yes, the factory filter is expensive, but I'd have warranty concerns about using a much cheaper knock-off. DIY oil changes will not cause warranty issues per se, but why give them a toehold to deny coverage.
Terpsmandan
Penn Yan
I work at a CDJR dealer and they are using Ecogard filters and Pennzoil 5w-40. I'm ok if they are ok.
Twowheels19
PA
‘22 JLURD
I’m sort of new to the JL forum and have a diesel on order.
Has anyone on here researched adding a remote oil filter assembly so that one could use a high quality, readily available and more affordable filter?
Thanks in advance.
Terpsmandan
Penn Yan
Compression-Ignition
Roy
Montana
'22 JLUR 3.0 Diesel, '20 6.7L F350, '94 12 valve
Thanks in advance.
I don't think he is talking about a bypass filter. Though they could work in conjunction with one another.
The way I read what he wrote, he is wanting to use a regular old spin on filter (remotely mounted, but inline) in lieu of the factory abortion. I had the same thought long ago. I'll get around to fabricating something one day.
Terpsmandan
Penn Yan
That wound not be a bad idea.
144treks
Maryland
2021 JLRU 3.0L Diesel, 2006 Liberty 2.8L Diesel
This is not a remote oil filter adapter at all. It simply uses the older style filter and provides an outlet, about 1/8", to send a small amount of oil to your choice of bypass filter for super cleaning and typically sending that cleaned oil back down the oil fill tube.
I am currently machining prototypes, in my spare time, for two different adapters. One is a full remote and bypass adapter using AN12 fittings and one which is a simple pancake adapter that allows a conventional spin on filter. Both will use the big Dodge Cummins filter. I will be using Amsoil EAO80, if you want to see the specs on that filter: https://amsoilcontent.com/ams/graphs/eao/filterspecs.pdf
Terpsmandan
Penn Yan
My bad. These two are our first trek toward the "Dark Side" as one of my techs who owns a Cummins said. Looking forward to seeing the results. At least FCA put the fuel filter in an easy to access spot.
Will
Grafton, WV
2021 JLURD
It's sad that there doesn't seem to be any intention form the top tier manufacturers to support this motor. I want a baldwin filter or some other high end filter. From their IPC Performance Report, I thought Ecogard was better than Mopar, but maybe that is not correct?
