Delrin Door Pins
Pinkyman
Ryan
Monticello, MN
2001 Jeep XJ, 2012 VW GLi, 2002 F-150
In case anyone is looking for the upgraded Delran door pins, TMR customs has them. They were a great fit, and came with the removal tool. It took about an hour total to put them on moms jeep, and the fit was great. I no longer have to worry about the salt in the MN winter mechanically bonding the doors to the Jeep.
Jeep Wrangler JL Delrin Door Pins ePsxx2X
Jeep Wrangler JL Delrin Door Pins 2dV19zI
Jeep Wrangler JL Delrin Door Pins G6ajTY1
D60
CO
JL
So bushings. I was wondering how an actual hinge pin in a plastic would hold up ;)
I wonder if they're using actual Delrin (Kleenex) or just packaging as such and using acetal (tissue). It would be cheaper to use acetal.
Bocephus
Virginia
Sam’s Decorative Automotive Button Emporium
I did this too...the original bushings were a pain to hammer out even with the tool!
Pic18
RI
2018 Mojito JLUR, 2017 Grand Cherokee Trailhawk (my wife’s)
I had these in our JKU and loved them. I didn’t think we needed them in the JL. Are the factory bushings the same in JK and JL?
Pinkyman
Ryan
Monticello, MN
I believe they are. From what ive read, the JK ones are a direct fit for the JL, so I think they are the same.
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
Keep the pins properly greased and make sure to open all the doors on occasion and this is a non-issue. You only need to worry if no grease and the doors sit unused for a long time that they will seize up.
