Cowl Mounted Light Bracket Pair for JL/JT
Exceed Fabrication
Peak Sponsor (Level 2)
Kelvin
Canton,China
exceedfab.com
2022 Gladiator Willys,Wrangler JK,Polaris RZR 1000
$42.99 for a pair
https://exceedfab.com/products/cowl-mounted-light-bracket-pair-for-jl-jt
  • Fits 2018-2024 Wrangler JL & 2020-2024 Glaidiator JT, not fits 4xe, mojave, 392
  • Removable stainless steel logo plate
  • Aluminum alloy with matte black powder coating, lightweight and high strength
  • Multiple custom pod mounting positions
  • Supports dual pods
  • Includes a pair of pod brackets and all mounting hardware
  • Three-year limited warranty on structure, three-year warranty on powder coating
Exceed Fabrication
Exceed Fabrication
Kelvin
Canton,China
exceedfab.com
Opus
Midwest US
www.jlwranglerforums.com
Seems to be a reasonable price for as sturdy as it looks and the number of mounting options it provides. Good luck.
Exceed Fabrication
Exceed Fabrication
Kelvin
Canton,China
exceedfab.com
This pod bracket currently supports up to 8mm screws. If the original screws of your pods exceed 8mm, we also provide 4 sets of M8 screws in each package for replacement.
Exceed Fabrication
Exceed Fabrication
Kelvin
Canton,China
exceedfab.com
Exceed Fabrication
Exceed Fabrication
Kelvin
Canton,China
exceedfab.com
Keep everything low profile and functional!
This side pod holder can move up and down about 0.8 inches, and you can install it upside down to make your pod lower!
Exceed Fabrication
Exceed Fabrication
Kelvin
Canton,China
exceedfab.com
We just did some testing and took some photos, hope it helps!
Apparently the windshield cannot be folded with the upper pod installed, and probably all the other brackets on the market cannot.
But after removing the pod, the windshield still has about 0.4 inches of clearance after folding, and it won't hit the bracket. Of course, we don't recommend doing this, because you're not sure if it will cause the glass to hit the bracket during aggressive off-roading. But it's a fun thing to try!
Exceed Fabrication
Exceed Fabrication
Kelvin
Canton,China
exceedfab.com
Some people were worried whether the bracket would be too high, we designed it so that customers can easily remove and install the pods without removing the bracket. We got Baja LP6, Diode SS5, Morimoto 4banger to test, and one thing I must clarify is that I think it actually looks bigger than the photo. If you care about the field of view, we recommend installing pods of 5 inches or less and installing them on the slope of the bracket as shown in the picture.
