Coolant flow noise
namrebo
Eugene Ernest
Pennsylvania
2021 Wrangler
Pipefitter Journeyman
My 2021 2.0 you can hear the coolant flow, just periodically. I’ve always assumed it was due to thermostat opening or some valve opening allowing the flow to go elsewhere. I didn’t notice it before I had the water pump TSB done, however, my coolant temps always look normal and I always run good at 195 Deg F.
Anyone else have this? I’ll post a video next time I remember on a cold start.
namrebo
namrebo
Eugene Ernest
Pennsylvania
2021 Wrangler
Should have put in there, it only does it during a cold start.
Start, will run maybe 20-30seconds you’ll hear it. Then In another 20-30 seconds again,noise, RPM drops to normal idle. then again for the last time, the noise. Then it’s gone. Until the next cold start. Like I said, don’t seem to be an issue. Literally been doing it for awhile, like 5-7k I bet ya. New to the forum, just figured i would throw it out there
