Combo/Drive Light Recommendation
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Hey Mike where did you tap in for the running light /DLR lead hookup?
Are you referring to the amber backlights for the LP4's? If so, I tapped them into the running light circuit of the Jeep. I didn't want to risk overloading just one side, even though they draw very little, so I tapped 2 into each of the front fender harnesses. The harness plug is behind the top of the fender liners, towards the rear of the wheelwell. I used a test light to confirm which of the 4 wires was the running lights, so I don't know the wire color off hand.
Ct_Formula
Orange Ct
2021 Rubicon JL, 2011 JK Sahara
Self Employed
Cool thanks Mike, I’m wiring in mine this weekend and didn’t want to miss any hidden wiring I could use.
She looks great man, I can’t imagine how bright they are in person.
Thanks again
What mounts are you using for the Apillar and ditch lights?
Headbarcode
LI, New York
Thanks again
Shit, I'm just seeing this now. Apologies for the delayed response! I have the Go Rhino cowl mount. I didn't use the u-shaped brackets that came with it because the Squadron Pros already had them. Plus, theirs are meant for larger pods. They should offer it without those brackets at a lower price. I just really liked the staggered layout and it's a very solid mount.
Jeep Wrangler JL Combo/Drive Light Recommendation 16172179163635402242955721663852
Ct_Formula
Orange Ct
Self Employed
I'm running the Diode Dynamics 4" on the center spot, then the SS2Pros for fog ditch lights. The SS4 pros were a little view blocking so I made some modifications and made a new bracket piece to extend them out farther and then powder coated them. They don't vibrate or shake or have wind noise so in my book its all a winner!
Jeep Wrangler JL Combo/Drive Light Recommendation IMG_4158
Jeep Wrangler JL Combo/Drive Light Recommendation IMG_4157 (2)
Jeep Wrangler JL Combo/Drive Light Recommendation IMG_4156
Headbarcode
LI, New York
The Squadron Pros are 3"x3" and just barely hide behind the registration and inspection stickers and the passenger side ones barely even blip my peripheral radar. Mine are setup the same as yours, as far as a forward facing spot and a wide cornering turned out and downward for ditch/flank lighting.
Good job with the bracket modification!
Ct_Formula
Orange Ct
Self Employed
Thanks man, I'm going to get creative now that I can powder coat steel and make some custom mounts for some BD for the front bumper
