Code P0E80 - Coolant Bypass Valve
IdahoJOAT
Caldwell, ID
2021 JLURe Tuscadero, Black '05 Silverado
CEL and no HVAC this morning...
My wife wanted to take me to work this morning, so off we went in Kailani II, the Tuscadero 4xe(Sep21 build, 26K miles).
CEL popped on, only cold air from the HVAC, and a coolant smell from outside the vehicle.
Made it to Peterson's in Nampa on electric only.
Josh ended up helping my wife when she got there. Code P0E80-00 was present. He's going to get it full diag'd today or tomorrow. He said it's the valve that is stuck closed, hence the overheating and no heat in the passenger compartment.
Then my wife sent me a picture of our garage floor...
So we'll see what happens. They were able to get us a rental, so @JeepCares , give Josh and Kent at Peterson's in Nampa a kudos.
Jeep Wrangler JL Code P0E80 - Coolant Bypass Valve Screenshot 2022-12-06 102815
IdahoJOAT
IdahoJOAT
Caldwell, ID
@XX4XEXX I saw you post in another related thread, just so you see that there's another one.
I should also have them look at the inverter and what else?
sconrad24
PA
2016 Willys JKU, 2021 4XE
Geez, I thought I was ok to wait on the coolant line seal recall but I guess they can work themselves loose anytime.
XX4XEXX
JD
Ca
2021 Rubicon
Mechanical Engineer
Hose routing if I follow you correctly....
Mgg253
Michael
2021 JLUR 4xe
To reference mine - I found no errors or issues so took it into the shop. They told me the code was thrown solely because the coolant was low. This was also the cause of the water whooshing sound coming from under my dash - air in the line. Seeing that your coolant is on the ground, could be just as simple of a fix
