Maverick909
- Brian
- Jan 15, 2019
- I.E.
- Website
- www.instagram.com
- 2018 JLU Sporticon, 1976 GMC K15, 67 Notchback Barracuda, Indian FTR
- Build Thread
- Link
- Occupation
- Electrician/ Industrial Furnace MFG
Installed my JKS 2.5” lift with adjustable LCA’s and adjustable track bar, myself something I’ve done quite I few times. Took it out for a trip and after removing the sway bar quick disconnects and air Down to 20psi started to her a minor clicking noise what sounds like mid point of the Jeep. Jiggle tested all the lca’s and track bar and everything looks good. About 40 mins later I get a good wiff of hot gear oil. lol under the new and see a little bit or white oil. I start thinking that the t-case is leaking but after looking at the Jl manual it’s ATF-4 in the t-case. This feels and smells more like lithium white grease. It looks like it’s coming from the front output shaft seal. In reality it’s coming through the push off threaded holes that are used to remove the drive shaft. When I installed the lift I did remove the axle side of the drove shaft and bungee cord it up so it wasn’t hanging on it’s own weight. Other things to note this was after a 4 hour drive in 102 degrees at 65-75 mph before getting to the TH. I’ve also had the alignment done at a local shop. Also NOTE that once I aired up and reconnected the sway bar the noise isnt there when cruising like it was air down. Only time I hear it is when under med-hard breaking or light to medium breaking to make a turn.. I’ve added pics of the grease I saw flung around. At first I thought water in the atf4 but it’s def not atf that’s coming out. Planning on a oil change for the t-case this week same as the rear diff. Anyone else have this problem?
