Cheap Harbor Freight Compressor just got cheaper
Newbalewb
2008 Wrangler X
I got my air compressor from NAPA and the thing airs up incredibly fast. No complaints so far
wcjeep
Earth
YJ with stuff. JL 2dr Sport
Upgrade the air line for the HF heavy duty . The included yellow line melts under moderate heat created by air compressors.
blnewt
blnewt
New Mexico
Just ask @cosine he knows!
Probably the case w/ my Viair too, I just make damn sure that hose stays clear of the compresion chamber and put a towel between it and the hose when cooling down w/ the hose coiled up.
wcjeep
Earth
The heat created by the compressor makes its way into the line. Think of it as internal venting. Depending on Tire size and original deflation pressure you might get 4 tires inflated with no problem. At some point the cheap yellow line can melt. Including a link to what might be the upgrade? It's not expensive.
https://www.harborfreight.com/14-in-x-25-ft-coiled-polyurethane-air-hose-61974.html
blnewt
blnewt
New Mexico
Thanks for the link, I think my Viair hose is a step above the HF version, but I'll keep that one in mind if I have issues.
oxidizr
Rich
2022 Jeep Wrangler Unlimited Rubicon
I hade my doubts last year getting a $99.99 on special tire inflator but 2 vehicles later and 35 and 37s this thing is the fastest inflator minus my Powertank. 37s from 12 psi to 38 psi under 4 mins a tire.
https://www.napaonline.com/en/p/BK_MTWM10215C
Its 25% off at select Napa locations
