FulThrotl
- Randy
- Feb 14, 2018
- Huntington Beach, CA
- 2018 JL Rubicon
my 3.6 gas JL has suddenly decided to regulate the charging voltage
at 12.9 to 13.0 volts. it'll spike to 13.7 for a second or two, and fall back.
no engine codes.
is there anyone who knows how jeep regulates the charging voltage,
and what i can do to solve this?
doesn't seem likely it's the alternator. it's a pretty new DC power 340amp
that charges normally at 14.4 volts, and will do a hot idle current of 200 amps.
it'll run a 3,000 watt inverter in the back of the jeep at idle. the voltage is just stuck
at barely above no charge at all.
dual battery optima group 25 with battery isolator. voltage is so low that it won't
even pull in the second battery for charging. lithium 300 AH in the back of jeep
won't accept charge at that voltage either. digital battery test says both batteries ok
everything seems fine except for the jeep won't let it charge.
any help would be greatly appreciated.
thanks.
no engine codes.
thanks.
