Low voltage light on at 13.6V
d k
Portland, OR
FJ Cruiser
Technician, engineer, home builder (wannabe), insurance, wealth management/retirement advisor
My battery light keeps coming at 13.6V.
this is a 2.0 if that matters. Resting state battery is 12.8-12.9V.
Any ideas?
alphawolff
california
2021 JLU
Any ideas?
If your battery light is coming on the detected voltage sense is outside the offset threshold of the target charging voltage. We've seen a few 2.0Ls with bad block grounds that cause the light to come on intermittently.
Using a scan tool you can compare target charging voltage vs voltage sense to see the difference. it shouldn't be more than 0.1-0.2v or so. You can crank the engine while doing a voltage drop (ground to ground) test with a DMM to verify the block ground. If you see any meaningful voltage on the DMM your block ground is bad.
d k
Portland, OR
FJ Cruiser
Now Im also noticing that the AC temp control doesnt work. Its stuck on ‘LO’ but blowing hot air.
Cips
Anthony
Bucks County PA
2021 Wrangler Unlimited Willys
Sales
It returns to normal in a day.
