From what I understand the connector is different between led and halogen.If the plug style is the same you could probably do it in your garage or driveway, no need to pay the dealer to do it. If the plug style is different You might want to just swap the bulbs and wait for the aftermarket to catch up.
That makes sense with them being totally different.From what I understand the connector is different between led and halogen.
HidProjectors makes their HID lights for JL. You can send in your housing or buy new from them. You have to have the halogens though. https://www.hidprojectors.com/collections/wrangler-jl-2018That makes sense with them being totally different.
The amount of work to try and swap in OEM LED's doesn't seem worth it really if you're going to it correctly since it would be necessary to swap out the wiring harness running to the fogs or try and craft a pig tail harness to plug into the factory plugs.
