Cargo Light
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
So I recently bought a Rough Country Cargo light. If anyone has any experience with this, Where do I hook the electric wire to?
Here is what I have
https://www.roughcountry.com/universal-led-dome-light-70982.html
If you remove the rear driver's side cargo panel, you can tap into the power that goes to the back of the 12V socket located there (there's also a ground nearby) or it may be possible to just wire it up to that style of plug and just use the outlet itself. Iirc, that location is always powered unless you swap a certain fuse in the engine bay, so be aware of that and whether or not you want it always powered or only with the ignition on.
Here's a video from @ExpeditionBuilds that shows a similar installation in that area..
