Wickedwhizer
I’m gonna get a 3” lift to run 35x12.5r17. Questions is can I run the 12.5 on the stock wheels without any modifications. 2021 wrangler rubicon.
Likely— “Standard guidelines for mounting 35/12.50/17’s is on 7.5–11.5” rims” , Tire and Rim Manufacturers Association —DT. …… no issues with stock non XR 392 wheels, including being even with the flares, no extensions necessary to prevent throwing rocks, debris, mud, etc on Jeep. Unless the increased lift creates rubbing or rubi wheels have a different backspace /offset.I’m gonna get a 3” lift to run 35x12.5r17. Questions is can I run the 12.5 on the stock wheels without any modifications. 2021 wrangler rubicon.
Note, can run on the street.Since a stock Rubicon can run 35s as-is why not use the lift money for wider wheels with a better offset?
Small rubbing on the back of the rear inner liner plastic when at full flex on the trail but not a big deal. No rubbing on the front.Note, can run on the street.
Remember stock wheelsSmall rubbing on the back of the rear inner liner plastic when at full flex on the trail but not a big deal. No rubbing on the front.
Read my original comment again. I was suggesting aftermarket wheels before the lift if they only want to run 35s on a Rubicon.Remember stock wheels
