Can you put bigger tires on the stock Wrangler JL wheels?
sixspeed
Gregory
Arizona
2018 Wrangler Sport S JL
It looks like you are locked into 245/75-R17–31.5 inches tall
Uhdinator
Maine
2018 JL Sport HT 2.0T Auto, 2003 TJ Rubicon HT
stock rims are 7.5" wide. Tire manufacturer lists minimum width as 7.5" for 285/70/17 or 295/70/17. Many have larger on stock rims, but I prefer staying within recommended ranges listed by brand. Some tire shops may also not mount them if too wide for recommended rim width.
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
Definitely not locked in at stock size. Anything with a 285 or 295 width will fit on a 7.5 wide wheel. If you want wider an aftermarket wider wheel is recommended. That being said people do put 315 wide or 12.5 wide on stock wheels you just may get funny wear due to the thinner wheels or have run lower psi to get even wear.
blnewt
New Mexico
Just ask @cosine he knows!
@sixspeed Keep in mind, the stock wheels for a Rubicon are also 7.5" wide and run 285/70/17s.
sdiver68
St. Louis
Wrangler Sahara 4XE, Tesla M3LR, Nissan Sentra
Management Consultant/Small Business Owner
Because I did not want the sacrifices associated with the height of 33" tires, I run 265/70/17 on my stock 7.5 wheels.
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
I did the exact same thing since my JLU is a daily driver.
