That size is closer to 34.5" tire. Not a huge difference from 35" but every bit helps with fitment.You can fit 315/70/17 on them equivalent of a 35” tire. You will need a lift and wheel spacers to do it though.
Depends on the manufacturer on actual tire sizes so I wouldn't be too concerned about it either way as the 315/70/17 is essentially a 35" tire. For example, a KM3 is a measured diameter of 34.5" in a 35/12.5/17 which is smaller than Toyo's 315/70/17 and measures in at 34.6". Toyo has a 35x12.5x17 as well and its 34.8" wide just for reference. Some companies don't even stock both size since they are essentially the same. (all measurements from manufacture websites)That size is closer to 34.5" tire. Not a huge difference from 35" but every bit helps with fitment.
If you are planning to do a lift, do that first. The lift will dictate what tire size you can fit.I appreciate the info. Already planning on a 2.5 lift. Just not sure which to do first.
This.If you are planning to do a lift, do that first. The lift will dictate what tire size you can fit.
