Best Strobe Light Switch (on/off and change function)
JSFoster75
Bluff City, TN
I have a 2019 jeep Wrangler Rubicon, I do not have the auxiliary switches, I am looking for an aftermarket switch that has a on/off switch with a push button that I can use to change the strobe pattern. The on/off switch would simply turn them on and off, the push button would activate and release immediately, just long enough to change the pattern.
The strobe lights have a black wire, a red wire, and a yellow wire, the black wire is the ground, the red wire is the hot, the yellow wire changes function.
any suggestions would be greatly appreciated.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Not sure if this is any help, because I'm not sure what type of light you have, but the SwitchPros SP9100 switch panel and controller uses water proof push buttons and is fully programmable. Each switch can be set to on/off or momentary, and also has strobe and flash capability with different patterns.
Not the greatest pic, but it's on the left mounted to the bottom of the grab handle. I chose red because it's easy on the eyes. The 2nd is the controller by the main battery where all hookups are made.
Jeep Wrangler JL Best Strobe Light Switch (on/off and change function) 20210131_185424
Jeep Wrangler JL Best Strobe Light Switch (on/off and change function) 20210216_120725
JSFoster75
JSFoster75
Bluff City, TN
awesome, thanks for the suggestion, the lights that I’m wanting to control just need a simple on off switch and a push button to change the flash pattern. These are white/amber strobe lights for emergency situations. They will all function simultaneously.
I will have a wireless Bluetooth switch for my other exterior LED lighting. I like the trigger six shooter plus.
JSFoster75
JSFoster75
Bluff City, TN
I ended up ordering these: https://www.superbrightleds.com/mor...-w-positive-trigger-surface-mount/5426/11955/
I’ll be installing it next week and will report back.
Jeep Wrangler JL Best Strobe Light Switch (on/off and change function) 81BA20BA-97A3-4F2E-9D54-1CA99E34AB13
