Best Pressure Gauge?
FRV
NC
2003 Suburban 4x4, 2021 JLU Rubicon
For me, auto deflators and combo pressure gauges with auto deflators are complicated, too expensive (for what you get), and too slow. There is a simpler and faster way to deflate.
I use a valve stem puller and a n analog pencil gauge. Unscrew the valve stem and grip the valve, still attached to the puller, with your thumb and forefinger. Keep it pinched. Check the pressure as the air rushes out. The air will come out fast. You don't need the valve installed to do it just push the pencil gauge down like you normally do when checking pressure. The deflation only takes 15-20 seconds to go from 38-18 psi. When the pressure is close insert the valve still pinched into the puller and spin it till snug. Check the pressure till it's right. You're going to be within a pound wtih a little practice. Simple and fast.
We have two sets of puller and pencil gauges. Wife does one side and I do the other. Whole thing for all four tires takes about 90 seconds to two minutes. When I have travelled with other jeepers they are still fumbling around looking for their pressure gauge or trying to spin on deflators--if they can find them.
There is a whole industry out there trying to separate us from our money convincing us we need stuff that isn't necessary. In my experience the most memorable adventures are accomplished with the least amount of gadgets.
Jeep Wrangler JL Best Pressure Gauge? IMG_3714
Jeep Wrangler JL Best Pressure Gauge? IMG_3715
roaniecowpony
roaniecowpony
Retired Engineer
I'm sure you carry spare Schrader cores. ?
I have the Apex RPVs. Haven't gotten around to putting them in yet. But they look like the fastest deflation device, next to the Teraflex wheels with their proprietary built-in deflators.
I'm going through this more often and just want to minimize the effort.
Rapid Precision Valve [STD] – Apex Performance Products (apexdesignsusa.com)
FRV
NC
Actually I do carry spare cores along with caps.
Absolutely use what works for you...as simple or complicated or time consuming or expensive as you wish. Or somewhere in between. No right or wrong. Options. Compromises. Whatever brings you joy.
Jeep Wrangler JL Best Pressure Gauge? IMG_3725
Mudduck
Jay
Michigan
2021 Willys 4door
I have a cheap auto zone slime analog stick style gauge that happens to jive near perfectly with my TPMS. I’ll stick to the $3.99 gauges myself.
