Battery/Starter/Alternator? Help
Mikev5521
Mikey
Chicago
2019 Jeep Wrangler UNL
I have a 2019 Jeep Wrangler with .about 30K miles, one day it wouldnt start. Headlights worked, windows rolled down very slowy. Got a jump and it started but the back camera didnt work anymore and Autozone said it wasnt the battery, but the dashboard showed the check engine light and battery light as well. Help!
Mikev5521
Mikey
Chicago
Thanks for replying Falcon, no mods. Wrangler Unlimited, no E Torque 2.0 L
ErAcEr
Matthew (Mateo)
Indianapolis, IN
2018 JLU, 2021 ZH2 , 2018 Z900, 2013 Vulcan 1700
Engineer/Technician
Mikev5521
Mikey
Chicago
Yes it does have an LED package
Mikev5521
Mikey
Chicago
How much will it cost to replace?
falcon241073
Trey
Byhalia, MS
2021 JLUR
I don’t know the cost but the ESS battery is small. I’d guess around $100-$150 max. But I’m guessing.
It’s under the fuse box. But it’s easier to pull the passenger side wheel liner and replace thru there. There are videos on YouTube.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
The battery light usually means low alternator output, did Autozone check the alternator output? If you don't drive enough to keep the batteries charged, you may need to use a battery charger.
Squibbles
Albuquerque
GTI, Ranger
I’ve never had a new vehicle’s battery last more than a few years. Replacing them with a higher quality battery they usually last about 5-8 years. Manufacturers will use lower cost batteries so at 4 years the alternator may play a part but the battery/batteries need to be replaced.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Replace both batteries. They are old.
